How to Disassemble an IKEA Hemma Cord Set
 by hanttula
Featured
Step 6: You're Done!
That's it. All the components should now be off the main electrical wire.
To provide an example of why you might wish to remove all of these components, I've included a photo from a recent test project: feeding the wire of the Hemma Cord Set through an IKEA Ekby Valter wall bracket (http://www.ikea.com/us/en/catalog/products/56696109/).
Daeglan says: Dec 20, 2012. 5:17 PM
Wouldn't it be easier and faster to just notch the wood?
hanttula (author) in reply to DaeglanDec 20, 2012. 6:11 PM
If this was an Instructable about making the hanging light, yes. But, that final picture was just to show ONE reason you may need to disassemble the unit. The Instructable itself was about the process not just what was shown in that final image.
Jimmeh30 says: Dec 13, 2012. 1:33 AM
The reason there are no instructions on the net for working on mains voltage is because it's FKN DANGEROUS if you don't know what you're doing, for you and for anyone else that does and has to rework your fk ups.
As pointed out by someone on a previous page, you could squeeze the bushing back in, instead of "breaking out the tabs" and probably compremising the integrity of the unit.
Doing this is a very simple process for the mechanically and electrically APT, for those who ARE NOT (not pointing any fingers) I would suggest leaving the pliers and screwdrivers in the hardware store, and paying someone who knows what to do, rather than follow, I dunno, an "ible" for eg, and break things while creating something that may or may not be dangerous given that you have no idea what you're looking at or wether or not the advise given is true, correct, or SAFE.
DustyBoots in reply to Jimmeh30Dec 13, 2012. 8:03 AM
"[b]We have a "be nice" comment policy.[/b] Please be positive and constructive with your comments"
Seems like you didn't read that part before engaging Flame Mode.
MrBillG59 says: Dec 9, 2012. 8:44 AM
Good job, but it might have been much easier just to cut the plug off and then put on a replacement plug.
hanttula (author) in reply to MrBillG59Dec 9, 2012. 9:12 AM
The plug end is molded in place (within the rubber/plastic). Taking apart the socket instead of cutting off & replacing the plug does not require any additional parts and allows for a cleaner "finished product" (since replacement plugs are usually fairly bulky).
ElZorro in reply to hanttulaDec 9, 2012. 1:59 PM
You could "keyhole" the bracket so that the light cord could simply fit without modification.
hanttula (author) in reply to ElZorroDec 9, 2012. 2:18 PM
Excellent point. The example of my particular usage was just to demonstrate a project completed from the disassembled socket. The focus of the Instructable itself is, of course, for those just seeking a way to take apart the Hemma cord set.
Snidely70448 says: Dec 9, 2012. 10:27 AM
http://electrical.hardwarestore.com/12-34-cord-ends-male-110v/flat-handle-plug-293670.aspx
This type of replacement plug is quite inexpensive, and not at all clunky.
hanttula (author) in reply to Snidely70448Dec 9, 2012. 12:14 PM
That does look quite good!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
