3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Disassemble the iPhone 3G
video How to Disassemble the iPhone 3G
This video will show you how to disassemble the iPhone 3G. Fix your iPhone's cracked glass or lcd and digitizer yourself. Made available by PowerbookMedic.com.
4 comments
Feb 23, 2012. 12:51 PMemiller17 says:
Thanks for the great iphone repair video. It is quite the process but definitely saved me quite a bit of money in the long run. I appreciate the extra advice from the comments. I am so happy to have my screen fixed!
Jun 5, 2011. 10:35 AMlesizz says:
The instructible doesn't state what size phillips to use. This is VERY important, as the wrong size either won't work at all, or could damage the screw heads, making them impossible to remove the next time you want to disassemble. I suspect the size is either phillips size #0 or 00. These can be acquired online or at hobby stores.
Oct 5, 2010. 9:49 AMdahayward says:
IMPORTANT: Do not pry up the screen as instructed in this video, as it may lead to cracking the very delicate LCD. Instead look halfway up the aluminum backing on the right side of the lcd, next to the middle screw. There you will see a small semicircle cut from the aluminum, gently insert your prying tool at that point to create separation between the two pieces, then using a pair of needle nose pliers, pull the screen off using the aluminum backing. This method ensures you never touch the glass of the LCD itself. Good luck.
Jul 31, 2010. 12:06 PMsnuggymonkey says:
thank you so much
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:powerbookmedic(PowerbookMedic)
PowerbookMedic offers free repair guides, parts, and repair services for Apple laptops, iPods, and desktops. Visit us at PowerbookMedic.com.
