But first let's consider the following scenario...
You are a middle-aged paleobotanist on the island of JURASSIC PARK!! Even though things seem okay at first, some evil fat guy has shut down the power to the electric fences containing all the vicious man eating dinosaurs! You are somewhere near the T-Rex pen enjoying a cool glass of water when the ground starts shaking and the water ripples. You turn around to see a very hungry looking six meter tall Tyrannosaurus Rex coming at you at almost thirty kilometers per hour! Luckily, there's a jeep just a few meters away. After making a quick dash, you hop in the driver's seat and turn the key...but nothing happens! As your eyes turn toward the shifter to confirm that it's in 'park' you see the unfamiliar 'H' pattern of numbers on top of the shift knob. You realize that this jeep is equipped with a manual transmission...and since you don't know how to drive it you can't even get the engine started. It's too late to learn because the T-Rex has already flipped the jeep over and is proceeding to peel off the roof to gain access to it's next snack. Sadly, you realize that this is what you get for forcing your husband to trade in his '64 Corvette convertible for a minivan because you refused to learn.
Don't be caught in this situation! Read on to find out how you could have escaped from the T-Rex's mighty jaws!
Remove these ads by
Signing UpStep 1: Advantages of a Manual Over an Automatic Transmission
Initial Cost: Manual transmissions are a lot cheaper than automatics. Choosing to buy a manual over an automatic saves you an average of $1000, depending on the make and model of the car.
Higher Gas Mileage: Manual transmissions are lighter and normally have more gears than their automatic counterparts. Also, a manual transmission doesn't have a hydraulic pump, which puts a big load on your engine. This can save you between 5% and 15% at the pump, depending on the make, model, driving conditions and driving style.
Lower Maintenance / Repair Costs: Automatic transmissions need regular fluid changes and are vulnerable to fluid leaks which can be very destructive. Many manual transmissions do not require any regular maintenance whatsoever. Repairs are usually more costly on automatics.
Better Control: With a manual transmission, the driver decides what gear to use. The best gear can be selected for the conditions (eg. low gear for going up steep hills or towing). Under these conditions, automatics often shift too high and end up wasting the engine's power.
Performance: In general, manuals have better acceleration and quarter mile times than automatics.
Fun: Automatics are boring as hell to drive. Manuals are fun as hell to drive!
Just a side note. If you have a manual car and for some reason you battery goes dead and you can't start the engine...just get your buddy to give you a little push and you're good to go! Can't do that in an automatic!
Visit Our Store »
Go Pro Today »
my first time driving manual i had no clue on starting from a dead stop. that was about the only place i ever stalled the car too, was starting from a dead stop.
to be honest each time that happened it was a "holy s*** what did i just do" moment, since ive always driven an automatic before. seeing as how ive ony driven manual once, im not going to give up on it though. and since manual cars get better fuel economy, itd probably be better for me to drive anyways :P
Of the majority of vehicles built in the last three years, autos accelerate faster, are more efficient and give better economy. No matter what your opinion is, it is a fact that computers running your gear box have more ability than you do to judge the best gear to be in. Please base your articles on facts not just your clouded opinions. You are correct that autos are generally more expensive than manuals when purchased, although the hold their value better too.
Nope.
In the UK, if you learn on an automatic, you are not allowed to drive a manual until you have taken another test.
Learning on a manual gives you a much better feel for the way a car responds in different conditions. Learning an automatic first creates a whole set of reflexes and responses that simply do not work in a manual car. Even things as simple as braking a manual car with automatic-car reflexes are far harder.
(British breakdown companies around airports are constantly having to deal with US visitors who have hired a manual car and and simply cannot cope because there are too many controls to think about at once - burned-out clutches and gear-boxes, over-heated engines, the works.)
Can you imagine not being able to cope with all of the controls at once while at the same time driving through a large busy intersection for the first time and not knowing where to go or whether to take or to yield? It's an accident waiting to happen whereas a person who is already framiliar with driving in an automatic can at least navigate the intersection safely; the burned out clutch is another story.
Of course the learning curve is not the same, and you must avoid trafic at the beginning.
In France (and probably in whole Europe), everybody learns on a manual, and everybody manage to get its driving licence at age 18, so its feasable :-)
What you say makes sense. But I'm afraid that somebody who is used to an automatic car, in case of emergency, will press on the brakes as hard as he can, and simply forget to shift the gears down or press on the clutch ... and wont stop at all...
When you are used to something and learning something new, it takes lots of time to change your habits. Moreover, old reflexes often comes back when facing unusual circmstances.
If ou are used to a manual car and you are loocking for the clutch pedal, during one second before you realize that ther is no pedal, while braking, it is not really dangerous.
But when you are used to an automatic, and you forget to change gear while breaking on a manual car, that can be dramatic...
Nothing that you learned on a manual could be dangerous on an automatic, the contrary is not necessarily true...
Thats why I believe that begining with a manual car, to acquire the more complex reflexes immediatly, is ideal, when you have the choice :-)
I'm sorry but I just can't see the danger caused by these automatic "habits" that you can "carry over" to a manual. Maybe it's because nether I nor anybody I know that can drive a manual has ever experienced them.
The difference between an automatic and a manual is really small, I mean it really is. It's the same thing as borrowing your friends car and the brakes or the gas pedal might be a bit more touchy or a bit more soft than yours. Or maybe it handles a bit differently... but you get used to it. And no matter what the car is like, the gas pedal makes you go, the brakes make you stop and the steering wheel makes you turn. Your driving instincts will do the rest.
Thanks for commenting.
British garages around airports are full of cars trashed by American tourists who cannot cope with that extra pedal and the peculiar stick thing poking up through the floor.
(I don't know anybody who died in a plane wreck - does that mean it never happens?)
Not true and contradicts the UK's own DSA advice on the matter. In an emergency brake as hard as you can and only clutch at the end to prevent stalling unless your cars manufacturer specifically advises otherwise because of a poor ABS algorythm.
De-clutching means the loss of engine braking, delayed response time, potential destability from the differential disengaging and prevents engine inertia (different force to engine braking) assisting in preventing rear lockup and further destability.
Lack of experience on any form of machinery is of course dangerous, whether ramping up a skill set via less complicated machines is a safer approach than being trained from the outset on the more complicated device is open to debate, the greater issue is more the practice of UK hire companies agreeing to lease manual cars to people who don't hold manual licenses.
Regardless of that, whilst the internet is a great place for expanding theories, when it comes to something like emergency braking procedures in an instructable aimed at learner drivers, I'd suggest presenting unproven personal opinions on the matter as opinions not facts.
I've pointed out that your contradicting official govenment safety advice from your area and described four effects that have been internationally proven and documented, but even better than me repeating myself, seeing as you've been on a rally course what did the instructor say about clutching whilst at threshold grip? If it went anything along the lines of what I used to teach my students (I was a circuit instructor not rally, but there's quite a lot of crossover) it would have gone something like unless your deliberately trying to destabilise your car... dont. That is also the reason why you dont see the BTCC and F1 drivers holding the clutch in whilst downshifting in their braking zone, believe me if just riding the clutch through the braking zone was faster and safer we'd do it.
I'm not interested in turning this into yet another debate on the internet, and I believe I've written enough and provided enough reputable sources for someone reading these comments to make an informed decision or investigate further for themselves, so I'm gonna finish up by saying as a widely respected employee and contributor of Instructables, commenting on emergency braking techniques in an instructable aimed at learner drivers, to an audience the majority of whom will be at some point in charge of a car on a public motorway, think very very hard about whether the information your presenting should be worded as your personal opinion or as a proven fact coming from an employee of this website.
(Are you aware that much of your advice only counts for rear-wheel drive cars? And that most manual cars are front-wheel drive? I didn't think so.)
It's a different situation when you learn on an automatic first and then learn on a manual second eventually becoming skilled at operating both types of cars. If every American did that before coming to the UK you would never see another burned out clutch from one of them again.
I'm a Canadian by the way, just in case you thought I was American.
In regard to a clutch and manual transmission requiring less maintenance, I would say that depends on the type of springs used in the clutch. Finger springs eventually break off and the clutch needs replacement. In my experience that seems to happen around 75,000 miles, give or take. I had an older car with coil springs in the clutch and the clutch was still fine at 130,000 miles. Most newer cars use the finger springs.
Thank you for your Instructable. It is possible for someone to teach himself how to drive a manual shift transmission. I think it would be a little easier to have someone experienced teach a new driver, though.
I've broken just about everything that can be broken in manual transmissions at one time or another. Synchros, shifter forks, layshafts, pressure plate assemblies, hydraulic lines, clutch cables, gear shift lever bushings. I don't count clutch discs, they're a wear item. They're like brakes, you have to bed them in if you want to get good life out of them.
