How to Drive a Manual / Standard Shift Transmission by LancePenney
Featured
Step 3: What's Going on Under There?
Having an understanding of what is going on inside the engine and transmission while you are using the controls is priceless when learning how to drive. We will look at all of the individual components of the car's powertrain starting with where the power is produced and ending with where it is utilized.
Engine: A device that converts the energy stored in gasoline into mechanical energy and heat. The mechanical energy is used to spin the flywheel and in Canada the heat energy is used to defrost your windshield.
Flywheel: A spinning disc on the outside of your engine that is used to deliver rotational energy to the clutch. It is the output of power from your engine.
Clutch: A disc that it attached on one side to the flywheel and on the other side by the transmission. The attachment of the clutch to the flywheel can be broken or made by pressing in on or releasing the clutch pedal, respectively.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
