Back in 7th or 8th grade I went with my mom to the gem show and one of the vendors there was selling loose stones. Seeing as how they were incredibly shiny, I couldn't pass up buying a pack of 'em (plus, I managed to haggle the price down to 80% off. that helped a lot.). The problem was, I had no way of actually using them. Professional pronged mounts? Nope, this is a middle schooler you're talking about. Bezel settings? Nah. They might've been doable, but I would've needed to be able to solder the bezel cup, and I wasn't allowed to use the blowtorch (huh. wonder why...). So I tried doing it this way.
Remove these ads by
Signing UpStep 1Materials
- a pair of round nose pliers (you could probably get away with a dowel you've tapered with sandpaper or something like that)
- wire (here I'm using 20 gauge beading wire from Michael's)
- a gemstone (in this case a 4mm brilliant cut cubic zirconia)
- wire cutters
Optional:
- *a fine file or some sandpaper (strongly recommended) to deburr cut edges
- 0000 steel wool to clean, straighten, and burnish the wire
- *a pair of chain nose pliers (they're always handy to have around)
*not pictured
I guess the hardest part would be finding the right size. You can buy something like this, or you can make your own with a bit of steel rod and a grinder (or even some sandpaper). The key is that it needs to be tapered if you want any control over the sizes, but if you only need one size and you know exactly what it is (keeping in mind that you need the wire to overlap the stone to seat properly), you might have better luck finding some square stock from a machinist's supplier like McMaster-Carr, or even Amazon.
Either way, good luck!
Check out this instructable for how to make it into a ring :)
And the good news is, now you know how to do it. Time to dazzle your friends :P
Also, not trying to be a creeper, but your profile says that poi is one of your interests. Which is awesome. Just by the way :)
