"Unblock" CMD
3,231
20
9
Posted in TechnologyComputers
Introduction: "Unblock" CMD
About: Hey there! My names Mr. Pines (not really m8, but just call me that). I'm a high school student looking to get into computer programming and such. I post some simple instructables about batch files and vbs f...
Hello there! You're probably here because your network administrator has blocked Command Prompt, one of the most useful tools a windows operating system has to offer. This is a VERRYY simple tutorial, so I wont go in depth with things.
Step 1: Batch File
This is a very short batch file to enter in notepad. Simply open notepad and type "start cmd" without quotes. Now click File, Save as, rename it to something such as "file.bat" Make sure you add .bat to the end or it won't work. Now click where it says "Text Documents" and change that to "All Files"
Step 2: ENJOY
Simply save, exit, run, and enjoy.
I may also post a batch script with fully customizable font color and background color. ENJOY YOUR SCRIPT!!
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Make it Move Contest
    9 Comments
    man, this is no good, when disabled by admin when I try to run this it infinitely opens cmd, which is, as i said, blocked. It states cmd is disabled by admin, press any key to continue...
    you have to open a new one in the textdoc and then name it file.bat and save the doc.
    then change the doc and add this tekst under it and then close and save
    Use this Code: echo off
    cls
    title Command Prompt
    color 7
    :command
    set /p input=Command:
    %input%
    goto command
    Hope this helped
    you could also just use this code to unblock it, it will bypass the firewall and open forcefully
    @echo off
    break off
    title C:\Windows\system32\cmd.exe
    cls
    :cmd
    set /p cmd=C:\Enter Command:
    %cmd%
    echo.
    goto cmd
    Dude, amazing, i've used title
    cls
    command.com before but this much better cause i'll not be running cmd
    i typed in notepad: start powershell and saved so i could use windows powershell
