If you're already on a special diet please continue to follow your diet.
I chose to take pictures at Wal-Mart. This is NOT an endorsement of Wal-Mart. I chose Wal-Mart because nearly everyone has access to a Wal-Mart and they carry both organic and conventional food. My health food store doesn't carry conventional food so I couldn't take pictures there.
I no longer moniter this Instructable.
Remove these ads by
Signing UpStep 1Do not eat hydrogenated and partially hydrogenated oils
The food industry uses hydrogenated oil because its a cheap way to add texture and taste to processed foods.
If youve seen a can of Crisco youve seen a lump of hydrogenated oil. Do not use Crisco or most margarines.
Also, it isn't necessary to combine proteins. Your body is going to break down the protein you eat into amino acids and again, it you eat a varied diet then you are naturally going to get all the amino acids that you need.
But other than that, this article is great! It's always nice to see other people trying to spread some common sense. Keep it up!
Also, the CO2-footprint of meat is very, very large, even for organic meat. It takes a lot of energy, water and other resources to raise those animals and proceed the meat until it turns up in the supermarket. One more reason to cut down on your meat-eating...
Your local (organic?) farmer might be another good source for quality meat, and you know where it came from, what he does or doesn't do to the animals, and it's not transported long ways to you. It also strengthens your community if you buy locally.
If you do want (or need) to eat out, check for restaurants with (the following are all and/or options) regional, home-grown, organic, fresh produce and a fair value-for-money-relation. A small menu with only up to 10 items or a "dish of the day" tableau usually hints at an owner / chef who likes to buy good produce in small amounts rather than have tons of freezer bag food in his attic. A good chef also won't mind telling you where the produce comes from or what's in it.
Most of the times you won't find these restaurants down the big shopping streets. A good place to ask for hints might be local farmer's markets or even organic food stores.
Good dining out normally starts at about 8-10 Euros for vegetarian or 12-15 Euros for meat dishes (in Germany), any lower for a normal sized 1-course dinner plate and you can be almost sure that the produce is not good. Rather eat out less and then spend a decent amount on decent food!
Go with the milk that's the least homogenized (pasteurized is fine: it kills the bacteria that makes the milk safe to drink. but, if you're buying locally, which everyone should do: then don't get it pasteurized). It might go bad faster, but once you get used to the real taste of milk (nd this IS the real taste of milk) it's quite healthy for you.
There is Organic Valley NON-HOMOGENIZED, Cream on top milk, but I haven't seen that much around. Strauss has a cream on top milk, and so does Stonyfield, which is the type I get.
Buy locally! And read the book Animal Vegetable Miracle: It'll change your life!
True that saccharine was accidentally "invented" by a guy attempting to work with some coal tar derivatives, but that isn't how it's made. Producers use anthranilic acid (AKA Vitamin L) combined with sulfur dioxide, chlorine, ammonia, and nitrous acid to create saccharine. No coal tar.
Naturally, consuming this combination of chemicals is less than healthy for you, and has been proven to cause cancer. I won't even get into the health problems caused by aspartame, or the fact that even the Nutra-Sweet company will admit that it breaks down to formaldehyde, ethyl alcohol, and a couple other nasties when heated to 85 degrees Fahrenheit (might I point out that the body is 98.6 degrees?).
Not flaming, just informing.
a link to the failed image, the image is of the splenda molecule, and to clear thing up more, my previous comment was for educational purposes.
