3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Enter the Ghetto Matrix (DIY Bullet Time)
Step 3Cut Wood
Cut Wood
Once you have all of the cameras placed and spaced properly trace the camera positions w/ a magic marker directly onto the ply wood. At this point you have all the necessary guidelines drawn that you need to cut the wood. Use the jig saw to cut out the arc. Make the width of the arc deep enough to comfortably mount all of your cameras and equipment. You may need to use two pieces of plywood to create your full arc. You can connect two pieces together by "sandwiching" the two (or three if its big enough) section of the arc between two pieces of plywood and securing them with large industrial clamps. Ours was roughly 9" deep. Be careful not so set the cameras so far back that the edge of the wood shows up in the bottom of the frame.
« Previous Step   View All StepsNext Step »
2 comments
Feb 17, 2009. 3:43 AMMVD says:
Safety tip, kids: Keep your fingers out of the path of the moving saw!
Jul 29, 2009. 3:06 AMiTraceur says:
Aw, no fun...
Jun 8, 2008. 6:57 PMmarty the fridge says:
mmm tasty
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:fi5e
Agent 005 of the Graffiti Research Lab
