3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Enter the Ghetto Matrix (DIY Bullet Time)
Step 5Stand Connections
Stand Connections
You will need to come up with a system for elevating your ghetto matrix off the ground. This could be done in many ways (including chairs, saw horses, stolen police barricades, etc), although keep in mind that you are dealing with a rather odd shape (one that is not quite as simple as a table top). Because we were looking for something that would be easy to transport between sets and something that would be fast and easy to adjust height and tilt we ended up using (4) compact light stands.
To connect these stands to our wooden arc we needed to buy 4 pipe flanges and 4 short pipe sections that where threaded on one end and were the right diameter and pitch to screw into the pipe flanges and also to accommodate the top tubular portion of our light stands. The spacing on these legs is not as important as the spacing of the cameras, so when you are deciding where to mount your flanges to the bottom side of the arc make sure that they are not interfering w/ the locations you plan to put the camera bolts. We had to drill and tap the pipe section (on the end opposite the thread) so we could use a set screw (a thumbscrew actually) to preload into the portion of the light stand that fits inside the pipe section. This allowed us to make a more secure connection between the platform and the light stands. Here is a drill and tap chart that will help you decide what size drill to use in order to create a nice tap.
(see the photo notes for more details on how to do this. Its dumb simple and easy to pictorially depict)
Once you are ready, you can drill your mounting holes and screw the flanges into place. Screw in your pipe section
« Previous Step   View All StepsNext Step »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:fi5e
Agent 005 of the Graffiti Research Lab
