loading
loading
Picture of How to Extend yout USB using UTP
This is my second Instructables. This time, I'm gonna tell everyone how to extend your USB using UTP. Why do you need to do so? Because the USB extender in shops only around 1,5 meters. It's very short, if you need 50 meters for a USB WiFi antenna on your roof. So I share to you people this technique.
P.S.: I will be making the Instructables of the Indonesia's style of USB WiFi antenna. The picture is below.
Step 1: Gather your parts
Picture of Gather your parts
You need:
(1)USB Cable
(2)UTP Cable
(3)Small PVC Pipe
(4)Rubber tape
(5)thermofit / heatshrink
Step 2: The making of Part 1
Picture of The making of Part 1
Open the UTP and USB cable. Put the small PVC pipe in the UTP cable. Put the thermofit in the USB cable. Then connect it like this:
white orange & orange to red,
white & green to white,
green to green,
and the rest to black.
Remeber to solder it.
Step 3: The making of Part 2
Picture of The making of Part 2
Fit the pipe in the connections and close it with rubber tape. You're finished! Try it. If USB is not detected, then change the USB 1.1 to USB 2.0.
If it doesn't work, try the circuit below.
1-40 of 99Next »
Use adapter to prevent power loss :)
jomac_uk1 year ago
There is a lack of research here, and a lot of misunderstanding about cables, ie twisted pair or shielded etc.
To put the record straight, its nothing do do with either of the above, you can have the best cable in the world, even fancy gold plated low resistance stuff, and the chances of getting any appreciable RELIABLE extra distance above the 5 metre limit is virtually zero.
The reason for this is not interference, nor is it voltage drop, but the timing of the signals that USB uses. Two of the cores are for power, +ve and Ground (red and black) the other two, green and white are clock and data (signal). The clock is a chain of pulses thats used to synchronise the data between the device and the PC, the data, well its just that. What happens when you extend a USB cable is to add a delay in the signals, for example, when a USB sevice wants to send data to the PC, it will do so on the start of the clock pulse, and any data it then sends is kept in step with the clock. As you increase the length of the cable, you increase this delay, to such a point where the data ends up completely out of step and meaningless to the other end.
There are other factors, but thats the reason in a nutshell.
ReneeC1 jomac_uk10 months ago
No, USB is differentially encoded; each data line is NRZI encoded data + clock. The D+ is the normal signal and D- is inverted. USB then uses a non-symmetric state to indicate end of packet. I cannot see how timing could be an issue when transmitting digital data over long distances unless one of the UTP pairs are of unequal length. USB does suffer from RF noise due to it's operating frequency, and at lengths also suffers from induced slew due to natural capacitance of the wires. The former can be guarded against with shielded-twisted-pair, the latter can only be avoided by keeping the cables short. High-Speed USB operating at 240 MHz is prone to RF interference at 720 MHz which is used by 3G and 4G cell phones. Full-Speed at 12 MHz or low-speed (750 kHz) would be far more practical at line lengths this long (aka, USB 1.1 if your BIOS supports downgrading or grab an old USB 1.1 hub from eBay).
jomac_uk ReneeC110 months ago
Its a timing issue....
http://www.usb.org/developers/usbfaq/#cab1
Those are active usb extenders, so they have some electronics at either end which allow further than normal transmission length (they use some other protocol/method than normal usb cables which allow longer distances). So they're not scams.
i need create an usb extension of 100 meters
can I use two lines to power a USB hub on the side of the female USB port ?
Sure, just add a capacitor across the power lines at the far end to smooth out power fluctuations.
lamelia2 years ago
Great uses of USB extender, KVMSwitchTech provides various kinds of USB extender products. To know more details visit http://www.kvmswitchtech.com/cat5-usb-extender-c11634.htm
lamelia2 years ago
rock2death2 years ago
Does 10 - 15 meters would work on a laptop?
what does that cirucuit above illustrate ?
niraj997993 years ago
I have a usb wabcame and i want to put in my office.. bt i want extend usb 25 meters so wat can i do?
Your best bet is to use a wireless Webcam. If you want to extend USB cables you'll need a repeater (or a USB hub every 5 meters) to do this properly. The USB2 specification is very clear about this. You may get ' lucky ' making a cable. But, the cost of making a cable (using quality copper cable) , and a few repeaters, and your time depugging problems will be more than an inexpensive wireless camera. Good Luck.
wcr_madmax3 years ago
The correct colors for any CAT 5 or CAT 6 cable are
1. slate-orange
2. orange
3. slate-blue
4. blue
5. slate-green
6. green
7. slate-brown
8. brown
I'm using a CAT 5e cable as well... so what color combination should I use to connect this to the usb cabling?
ftube3 years ago
hi first thanks for the great work.
i tried that and its showing USD not recognized pls tell me how to solve this issues?
i am using windows 7 os
mlapid3 years ago
I made 7meters extension and it works fine. But it randomly disconnect my wifi usb adapter. Can someone help me?
bebub123 years ago
http://www.my-fisher-price.ru/
why does it tell me that my usb device is unrecognized when i plug the device into the usb cable?
i got that same thing in windows 7, whats going on is that it doesn't have enough power, So what i did is set my motherboard to USB 1.1 in the BIOS and it work fine. But i works fine in linux with out setting all usb to 1.1.
In windows 7 if u dont want to do the USB 1.1 thing u can get it to work with some of the back ports of the PC try each one and try like a pen drive and the WiFi dongle then again i should say " may get it to work "
right now am looking to implement the following to try and solve my problem http://www.howtofixcomputers.com/forums/hardware/stupid-question-remote-usb-95093.html , http://193.189.160.28/seibert/HP/UsbEnh/UsbLongCable2.gif , http://193.189.160.28/seibert/HP/UsbEnh/UsbLongCable.gif o yea and this to http://imamqu.blogspot.com/2010/10/additional-power-supply-for-usb.html
mmariappan3 years ago
thanks its superb!!!!!!!!!!!!!!!!!!!!!!!!
works nicely
I am from tamilnadu, india
j21a2t896 years ago
Just a quick point you could use a usb hub (with all the plastic stripped off) to regenerate the signal. So using the utp as well you could extend the cable theorectically to any length. You would need to remove the power socket on the hub and have a powerful enough 5v source. hmm i should create an instructable.
This is correct although you would need a USB hub every fifteen feet or so.
i was tried using 15meter utp cable.but not works coz the power is drop down.
15 Meters is WAY too long.
zeefar6 years ago
When I connect the flash drive to the connector through the set up of USB over UTP to PC, the computer does not read the data from my flash drive device, why is that?
Most USB devices won't work with an extension that long without the aid of a USB powered hub. They use 5V provided by the computer, and the voltage drop over more than about 20 feet is enough to create a "USB device not recognized" by the PC. I Use webcams for security on my home, and have to use a powered hub or it won't pick the cams up. Try it.
 what if you use a USB "y" cable? that draws power from 2 ports, therefore doubling the power... am i correct on this?
No. Drawing power from two ports won't affect it. It will probably fry the USB device however. And even if it was plugged into two different ports on the computer it would only be able to transfer data from one.
It isn't the voltage that is affecting it. If the cable isn't shielded the interference could affect it or the data stream isn't powerful enough. It isn't voltage.
Your cord must be too long then
Hi there. I already made up a 10M USB 2.0 cable and I thick I remember it works ok from the computer with a webcam. But I want a longer USB cable to use the webcam to take photographs about the house and outside. Can I use this telephone cable. It has 4 wires and is used for the telephone but I am not sure if it is the same as the UTP cable.
You need 5 for ground wire
Thank you.
In correction to the needing five statement, If the cable is shielded it'll work with just the four.
bayucandra5 years ago
This man doesn't included the detail way of put the IC and the input power, if some body need more clear picture, try to visit http://www.dhegleng.or.id/qe3/?p=136. I don't know is the man who wrote this instructables article and the man who wrote the article at the link i gave is same person. But the link i gave have more clear description. The problem only that my link is in Indonesian language, but don't worry it has clear picture just to see.
Hi Bayucandra,
thanks for your idea for using regulator IC7805 to power the usb device at farther end.but what is the maximu length of cable u have used.
tks.
danraja4082@gmail.com
anjumraza4 years ago
i was worried after puchasing evo usb for net surfing.signals were very week i made the utp wire and connectors and found that the signals were very high even a distance of 24 feet from computer to usb..thx instructable ...i loved that
1-40 of 99Next »
