After glancing around the net for tutorials I came up blank. That's when I decided it was time to come up with the technique myself. Hopefully, someone else with the same problem will come across this instructable and save themselves the time it takes to figure this out.
Remove these ads by
Signing UpStep 1How Thermal Imaging Works
There are basically three ways for a camera to "see in the dark". Light amplification is the most commonly used method. It is really just the gain on a camera and tells the camera to increase the amount of visible light it is collecting when the light source is faint. Also common on consumer camcorders is the nightshot feature, which lights the area in front of the camera with infrared light which can't be seen by human eyes, but which the camera can see. It then converts what it sees into video in the same way it normally would. These images tend to be pretty desaturated with a tint of green. Think Blair Witch Project, and you'll probably have the right idea.
That leaves thermal imaging, which uses cameras that do not operate with CCDs (charge-coupled device). Instead most thermal cameras use a concept called FLIR (forward-looking infrared) that captures thermal radiation and creates an image based on temperatures. These black and white images are then assigned color values and our easily recognizable thermal images are created. FLIR isn't the only thermal radiation system, but I'm guessing it's the most common, and the one I studied to understand the process.
9
comments
Add Comment
yokozuna (author)
says:
CameronSS
says:
yokozuna (author)
says:
CameronSS
says:
yokozuna (author)
says:
Add Comment
