3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Fiberglass: Fixing a Cracked Kiteboard
Step 2Sand Down/Out the Bad Fiber Glass
The first step in fixing a crack is to sand out or down the broken fiber glass. It comes away pretty quickly if you use an abrasive pad on a power sander or angle grinder. Be careful though, you can easily take off too much material and grind into something that you didn't want to.
There is no hard and fast rule that says when you have taken out enough of the bad glass. A good rule of thumb would be to clear out a section of fiber glass a few inches around the original crack.
You'll be sanding through hard little pieces of old fiberglass and epoxy and you certainly don't want to get any of that stuff in your lungs or clothing so now is definitely the time to wear the proper safety gear.
If you are starting a new fiberglass project and not using it to fix a crack then you won't need to do this step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
889
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
