How to Field Strip an Airsoft Gun
This Insructable shows how to field strip a gun(pistol).
Step 1Safety First
The first step is to make sure your gun is not loaded and to take out the magazine.
35 comments
Sep 27, 2011. 8:00 PMilpug says:
This is an incomplete instructable, and only works on guns of this design.
Mar 27, 2011. 5:32 PMUnChArTeD says:
Point Exactly?
Mar 6, 2011. 6:03 AMHitman227 says:
Is that a beretta 92fs rep. ?
Apr 22, 2008. 3:22 PMthewoodcarver says:
lot different then a 1911 , a S&W, or a Kel-Tec field strips ....thought it was going to be a real gun
May 15, 2008. 9:01 PMVertigo666 says:
My airsoft 1911, you just push/pull out the slide lock lever.
Same.
May 15, 2008. 11:26 PMthewoodcarver says:
On my 1911 I have to drop the mag eject the bullet check the chamber to make sure it is unloaded push down on the front of the barrel and move a key to the right making sure the recoil spring don't fly our ...on the smaller ones I have to stick a bent piece of metal in a slot move the slide back after I make sure it is unloaded...my old .38 S&W model 10 revolvers are the easiest to clean followed by the Glocks....he changed the title since I posted the above I thought it was a real gun when I wrote comment ...I have since gotten my son and myself 2 air soft type knock off's to see what all the hype I see posted about them was about shoots a small orange pellet lots of fun takes me back to my red ryder bb gun days and yes I do have both eyes
Dec 22, 2009. 10:47 AMspn_phoenix_92 says:
so, whats the point in field stripping an airsoft gun?
Feb 22, 2011. 12:34 PM444fox says:
IF it gets jamed
Dec 13, 2008. 12:20 PMcbrown222 says:
i have a crossman can i still do this
Dec 14, 2008. 4:49 PMcbrown222 says:
wut dou mean two levers
Nov 7, 2010. 1:09 PMRMConstruction says:
Oh go home.
Oct 28, 2010. 1:19 PMgunman15 says:
nice
Apr 21, 2009. 5:44 PMChefZombie says:
This doesn't work on all airsoft pistols.
Nov 1, 2009. 12:04 PMZansion says:
This works on all professional grade gas blow back airsoft pistol. if yours doesn't, i suggest you trash the pistol and get out of the sport.
Oct 22, 2010. 1:25 PMChefZombie says:
Chill, I meant different guns have different ways of field stripping such as a m9 doesn't field strip the same way as a desert eagle.
Oct 21, 2010. 9:16 PMnegative nancy says:
No it doesn't. Most gas pistols depending on the brand, and the model the replica is based off of, have different ways of being taken apart and cared for.
Mar 21, 2009. 6:37 AMN1CK4ND0 says:
What is the gun you used in your picture?
Dec 5, 2008. 11:32 AMYour Average Guy says:
Yeah i have a SIG like that. Ive been playing airsoft for a couple years and only have a spring pistol. hahaha.
Nov 29, 2008. 5:36 PMmichael9319 says:
good instructable, but this only works for the m9 series, if you have an m1911 it will strip differently, along with the glock series, desert eagle, walther, and other oddballs like the cz series, and some of the SIG's.
Nov 26, 2008. 3:31 PMgoeon says:
i added you to the airsoft guide
http://www.instructables.com/id/Airsoft_8/
Sep 29, 2008. 5:43 PMfinnster says:
i used to do this to annoying little kids in my neighborhood, then say i broke my gun, then reassemble it in a few seconds and shoot them
Sep 30, 2008. 12:05 PMfinnster says:
screaming and running away(they were always stealing my stuff)
Apr 22, 2008. 6:37 PMMD_Willington says:
The lever is the take down lever, actually the take down you are showing is similar to a real take down, I do not have it on video but the take down for my S&W 5906 9x19mm pistol is fairly similar, as it is with my Taurus 9x19mm pistol...
http://www.alpharubicon.com/leo/breakdown5906.htm
Aug 30, 2008. 3:11 PMubr.bzkr says:
Thanks man. I've been trying to do this all day and I couldent figure out how to slide the bolt out. haha now I can try and mod it.
Jul 1, 2008. 2:16 PMStorm950 says:
Shouldn't the instruction manual explain how to do this? Although at least this instructable is of high quality.
Apr 21, 2008. 4:00 PMac1D says:
I add lubrifiant on mine, i dunno if it make it stronger! any airsoft expert can tell me ?
Why wouldn't you? Doesn't make it inherently stronger, might make it easier to slide.
Jun 28, 2008. 12:06 AMbenthekahn says:
And it would increase the power.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:grimfig
