3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Finish Concrete
Have you ever seen a sidewalk poured with new concrete and watched someone finish the concrete? You probably didn’t pay a lot of attention but you noticed someone down on their hands and knees with a trowel moving around the concrete surface. Like everything else that is done by someone with experience, it looked easy. Guess what? It’s not that easy unless you have done some homework. Sakrete is here to provide you those tips and instructions on how to finish concrete like a pro.
Step 1Pouring the concrete
After thoroughly mixing the concrete pour it into the forms slightly overfilling them. Then take a straight board (a 2x4 piece of lumber works great as long as it isn’t bowed) and simply level off the concrete. Using a board that is longer than your pour is wide and using a sawing motion work back and forth until the concrete is level. You really need someone on the other side to help with this part. This is called “screeding” if you are trying to learn new words with which to impress your friends.
2 comments
Sep 24, 2010. 6:24 AMdchall8 says:
Thank you for your series in making concrete projects. Every now and then someone wants to make a casting project with a concrete and a mold. Sometimes the "top" of the final project will be the shape of the mold (flipped over after curing) and sometimes the top will be the top surface of the dried concrete. Do you have recommendations for making smooth surfaces when casting flat or curved concrete? The projects I'm thinking of would be smooth enough to apply wax for a perfect shine.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:Sakrete(Sakrete)
Sakrete is the pro's choice for concrete, mortar and stucco mixes along with maintenance and repair products for concrete and asphalt. Contractors and do-it-yourselfers rely on Sakrete for quality, co...
more »
