How to Finish Painted Table Tops | Tough Coat Tutorial
Published
Introduction: How to Finish Painted Table Tops | Tough Coat Tutorial
About: Country Chic Paint is a beautiful clay-based furniture paint specifically designed for DIYers with a love for refinishing furniture and home decor. This fabulous paint is zero VOC and contains little to no h...
Tough Coat from Country Chic Paint is specifically designed to go over our furniture paint; it provides top-notch protection for surfaces that get a lot of use, such as table tops and kitchen cabinets.
This scratch-resistant, water-based topcoat has a very low odor and it will not discolor the paint. The finish is crystal clear and resistant to household chemicals, alcohol and water. It dries quickly (without staying tacky), and is environmentally friendly, with easy soap and water clean-up.
This product can be found at www.countrychicpaint.com.
Step 1: Paint Your Piece
Tough Coat can be applied to almost any water-based surface, but it’s generally used to seal in the finish of our paint.
It is very important to make sure that you let your last coat of paint dry for at least 24 hours before proceeding with Tough Coat, otherwise you may end up with a streaky finish.
Step 2: Stir the Tough Coat
Tough Coat should never be shaken. If you do shake it, you can incorporate bubbles which may appear on the finish of your piece. We recommend stirring the contents of your jar for about two minutes, an occasionally during application if you’re working on a large piece. You don’t want important ingredients to settle at the bottom!
Step 3: Apply Tough Coat
Using a foam brush, apply Tough Coat in long, smooth strokes in one direction. Tough Coat dries quite quickly, so you’ll want to keep a wet edge and avoid going over the same area twice. If you see a patch you’ve missed, resist the urge to go back and fix it. It’s better to wait until the first coat is fully dry before you do touch ups or you can add texture to the finish.
It is best if the temperature that you are working in doesn’t exceed 70F or 20C. If you find that it dries too quickly, you can thin Tough Coat with up to 5% water.
Please note: NO wax should ever be used underneath Tough Coat.
Step 4: Add a Second Coat
We recommend using two coats of Tough Coat for optimal protection. Your second coat can be applied after approximately 2 hours.
Step 5: Cleanup
Since Tough Coat is water-based, it can be easily rinsed out of your brush with water and a bit of soap if needed. Your table top will be ready for use in 24 hours, but it’s best to wait about a week before you scrub it down at all. Give it a chance to fully cure before subjecting it to any intense cleaning.
Step 6:
In this video tutorial company co-founder, Rosanne will show you how to apply Tough Coat to achieve a smooth, beautiful finish that will protect your work against daily traffic.
    • Backpack Challenge
      Backpack Challenge
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
