How to Fix Broken Headphone Jack !
76,353
369
47
Posted
Introduction: How to Fix Broken Headphone Jack !
Note : I know many of you will say that's PLUG and not the JACK. Not technical people generally refer it as a jack ! and my videos and Instructables are for everyone so just chill out and enjoy :)
Many of us love music, especially on earphones! but the problem is rough usage and broken headphone jack. Have you ever came across such problem? Then I can show you how to fix it ! so let's get started
Step 1: Watch the Video !
Click Here to watch it
If you are lazy and don't want to read all stuff you can watch my video! And it is much easier.
Step 2: Lets Start
So the very first thing grab the broken pair of earphones and cut the wire just above the broken area. Then use something like a box cutter or xacto knife and remove the rubber on top of jack. After the if you have plastic on the jack remove it using pliers.
Step 3: Check Jack
Ones you have the Jack we need to check if it is still functional we will use multimeter`s continuity function for that. Mine is still fine! If yours is not you need to order new one
1) https://www.amazon.com/Uxcell-10-Pieces-Black-Plas...
2) https://www.amazon.com/3-5mm-Repair-headphone-Sold...
Step 4: Clean Jack and Prepare Wires
Now clean the jack and remove the wires from jack using soldering iron. Now take other end of the cable and remove the outer rubber. You will see 4 Wires
Copper is for GND
Green is for Right
Blue is for Microphone
Red is for Left.
Step 5: Soldering
For Soldering the wires here is the schematic solder it and you are done
Step 6: Check Jack Again!
Now plug the jack and check if it is working mine is working so we can proceed ahead. if yours didn't work check if soldering is done properly if not then you have to open the earbud and check if the manufacturer has changed the wiring!
Step 7: Final
So finally we have fixed it but we can't use it like that it will break in few hours so we can use heat shrinking tube to cover it!
Step 8: Thank You !
Feel free to check out my YouTube channel for more awesome projects:
https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects and behind the scenes information
https://www.facebook.com/NematicsLab/
https://www.instagram.com/nematic_yt/
https://www.snapchat.com/add/nemeen
https://twitter.com/Nematic_YT
  • Something Similarhtt...-RajenderK4
    RajenderK4 made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
43 Comments
I cannot support a stereotypical error on the part of "the rest of us" The object of an instructable is to "instruct" or educate. Accepting the incorrect nomenclature, calling it a Jack and not a Plug is inexcusable. IT IS A PLUG, instruct "the rest of us" and promote correct nomenclature.
Except you wouldn't be searching with those terms, cause you wouldn't know them! So he made a choice and used the layman's name of the item, people can then find his article, read it, and they'll immediately see the part where he says it's not actually a jack. Then, if they care, they can search for the correct term. His ible is on fixing an electronic part, not on proper terminology, so he wrote this accordingly in a manner that will attract the largest number of readers.
I think there are relevant points from both sides regarding the proper term usage (and the point of Instructables, is to instruct, to teach) but the part that kept hanging me up was when you (for instance) mention to "check the jack" I kept thinking I should check the (actual) Jack (not the plug). Kinda confusing. Otherwise nice Instructable (-ish)
The part you describe is the plug, rather than the jack. The jack is the receptacle that the plug inserts into. Otherwise a useful Instructable.
Yeah I know but non technical people refer it as Jack so some sort of clickbate :P
I use the words "plug" and "port", exclusively. I've seen words like "jack" used both ways, and that is confusing. We all know what a plug is; every appliance has one. Port? well that's where ships come in; "socket" would have been a better word for port or jack, since we are dealing with electrical/electronic stuff. Otherwise, thanks for putting up the Instructable, Nematic.
Good instructable. I only needed to use heat shrink tubing to restore my plug to good health. Thanks for the details.
This is great diy stuff, but unfortunately this out of most people’s ability range or would be hesitant to do. On another note, when using the shrink tubing one could double or triple up on the shrink tubing for added support. Or use a plastic dip material they use on plier handles etc, this very durable. This certainly is a good fix on original Apple lines because of replacement costs. Thanks for the tip
If possible, I'd rather replace the plug with a brand new one, preferably from Neutrik (if a company has a proven track record in professional audio industry, I buy that!). I don't know if they have 4-contact version though; regular TRS is easy to get.
Nice instructable. As another commenter noted, "tin" the bare wire ends with solder before trying to attach them to the 4 tiny lugs. And notice Nematic!'s *very* quick and light touch with the soldering iron. He makes this look easy, but try it yourself and you'll appreciate his technique!
