3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Fix Earbuds
How to Fix Earbuds
After throwing away my fifth pair of $15 earbuds i was sick and tiered of these things breaking, so when this pair broke i got out my X-Acto knife and started cutting.
Step 1Materials
Materials
The problem spot is usually right at the end of the headphones (duh). The problem is that the wires get bent so much that they break(another duh), but this can be easily repairer with the following materials:
.wire stripper
.different sizes of shrink wrap
.soldier
.soldiering iron
.X-Acto knife
.copper sheet (optional)
.matches
37 comments
Jan 2, 2012. 5:09 AMquantuminduction says:
I didn´t understand the good wire and bad wire stuff.
can u explain it to me please!!!!!
Nov 23, 2011. 11:36 AMeijams says:
OK SO MINE HAS FIBERS OF CLOTH ON THE INSIDE OF THE WIRES ...WHY
Sep 3, 2011. 9:00 PMwsikes says:
Does this work for iPod earphones? would it also fix the jackmic? also I like the sony barnd earbuds they last a long time they're only $10 and once one of them shorted out and i just left them for a week and didn't use them and when i came back and tried them out they worked again.... until my brother stepped on them.
Aug 21, 2007. 9:14 AMjoemonkey says:
ipod head fones are the best. they are $28.99, but the ones i got with my 1st gen nano work still and theyre a year and a half old.
Mar 16, 2011. 10:04 PMjaraya says:
Mine JUST broke. I haven't even had them a year yet. only a couple months. UGH! they're my ONLY earbuds, and I don't have the money to buy new ones -_-"
Jan 29, 2011. 10:17 PMCheezmonka says:
My earbuds have a threaded cord. As in like, material, fabric, not regular rubber coating like most earbuds. How do I go about repairing them? If it helps, the brand is "lenntek".
Dec 7, 2010. 1:27 PMxXSasoriXx says:
can we use a diff. type of knife?
Sep 16, 2010. 6:28 PMmisteravocado5 says:
Sorry if I'm not understanding this, but wouldn't the blobs of solder touch together inside the heat-shrink wrap and short the thing out? How are the three little wires insulated from each other once you solder? Thanks.
Apr 15, 2010. 1:54 PMEl Mano says:
I love not having soldering equipment. My electronics look so homemade, all the wires held together with tin foil and tape.
Jun 29, 2010. 11:53 AMnabsol says:
so does that mean on the part where he solder the wires u just put foil paper? or electric tape
Jan 28, 2010. 1:36 PMentreri says:
My $16 skull candies did this, i dont have a soldering iron or shrink wrap, what else could i use? would ceran wrap work? it doesnt seem like it would and i dont want to test it.
Sep 8, 2009. 6:40 AMvbsoto says:
I made a similar repair after reading hear about removing the coating. It worked for about a week, then I started getting drop outs again. This time I went to the Dollar and bought a donor pair of earbuds. I desoldered the cord off the buds. No coating to deal with and they were already tinned. Soldered the new plug and cord onto the good buds and presto! Worked like a charm and easier than all this other hassel.
Aug 22, 2009. 1:26 PMdrumsticks135 says:
hey, i'm wondering if anyone knows how to fix this problem: my ear buds have been fine, except this week i noticed that the right ear is significantly softer in volume, but the signal is still crystal clear. so if i plug them into my computer i can pan the volume more right, and it sounds fine, but if they are in my ipod it's still messed up.
Jun 10, 2009. 7:24 PMgrey_fedora says:
I used this instructable to fix my earbuds, and they have been working perfectly for weeks now. Thanks!
Dec 5, 2008. 4:14 PMcodongolev says:
I couldn't get the solder to stick. any suggestions?
May 28, 2009. 6:40 PMkeefurxxcore says:
You need to burn/ sand off the insulation off of the wires.
http://www.alexwhittemore.com/?p=205
May 29, 2009. 2:14 PMcodongolev says:
thanks, but I got it figured out since then.
May 29, 2009. 3:13 PMkeefurxxcore says:
Heh, thought so, just wanted to put it up.
Aug 28, 2008. 2:55 PMsmeurer says:
my cat cut my earbud wires is there anyway to fix it please let me know my e-mail is smeurer@neo.rr.com
Aug 30, 2008. 12:44 AMDELETED_yoghurtsniffer says:
(removed by author or community request)
Aug 31, 2008. 11:29 AMsmeurer says:
the cord leading to the earbuds
Jul 17, 2008. 8:11 AMkenny94 says:
mine did this straight out of the box
May 6, 2007. 2:54 PMvisus says:
Just FYI, it's safer and better practice to shrink up shrink tubing with a hair dryer.
Mar 12, 2008. 9:07 AMn0ukf says:
hair dryers may not concentrate the heat enough. Rather than that or matches (or lighters), I hold the shrink tubing very close over the soldering iron. It may not be as fast as a flame, but there's less chance of burning the tubing or the wire insulation.
You can also use a heat gun like what they use on model airplane monokote (and similar) heat shrink coverings (also used for stamp embossing). Here's one source (random search) http://www.hobby-lobby.com/heatgun.htm this has a removable concentrating nozzle that would work nice for doing wire heat shrink.
Jun 28, 2007. 8:06 PMducks says:
The problem I was having with my earbuds (2 pair of Sony's) was that the sound in one ear would just stop. I'd remove the soft rubber ear piece and clean the cover which would seem to help - for a while. But both pair eventually had one ear that stopped for no apparent reason (wires and plugs were okay). After exhausting the cleaning approach with both pair, I decided to try to poke a few holes in the material that covers the small plastic tube, and to my horror, ripped it completely loose. After being sure that I had completely ruined them, I put the soft rubber ear piece back on, plugged them in and voila, they worked fine. The cover that I ripped off is apparently just to keep ear wax, sweat, etc. from entering the plastic tube and ruining the internals of the earbud. I took a small amount of cotton and filled the small plastic tube as a substitute for the small cover originally glued to the end of the tube, and both pair of my earbuds have worked fine ever since.
Aug 22, 2007. 6:04 PMducks says:
Well, that fix lasted only a couple of weeks - was unable to get them to work again after that. Now using new set of earbuds - Bass freq - after doing a fair amount of online research . . .
Jul 25, 2007. 11:50 AMzootboy says:
with my headphones, i have needed to replace the entire jack. It works the same way, but you solder the wires onto a new jack from radioshaque.
May 14, 2007. 10:39 PMThe_K-man says:
I tried this with my broken $40 pair... After stripping the wire, I found 4 separate wires, and they were not regular wires. They seemed to be made of gold-colored cloth and they were very threadlike, and did not hold their shape if I twisted them. Soldering was unsuccessful. Anyone have any tips? I'll have to try again later.
Jul 18, 2007. 8:28 PMJames (pseudo-geek) says:
the wire is a thin, enameled wire. (either steel or copper) "enameled" means it has a VERY thin insulation coating rather than a thick one. this makes it to where you can use a very thin cord. (plus you can bend it alot).
Jul 18, 2007. 8:29 PMJames (pseudo-geek) says:
oh, and to solder it, before you put the solder on, burn the enamel off with the soldering iron.
Jun 4, 2007. 3:03 PMn0ukf says:
if you look closely enough, you'll see this is probably a ribbon of foil-like wire flat-wrapped around some kind of fiber (nylon, teflon or whatever).
Jul 18, 2007. 8:27 PMJames (pseudo-geek) says:
May 12, 2007. 10:16 PMmondaymonkey says:
I got a really good idea. Buy a good pair of head phones. Like the ones i got on right now are some samsungs. Before these, i would go through one about every 2 weeks. It sucked. So i decided to buy some good ones and iv had em for about 6 months so id say thev lasted a long time
May 7, 2007. 7:43 AMich bin ein pyro says:
when i saw this im like ah! this is the solution to my broken headphone! i look in further and see thats its how to fix the jack-wire connection but i have a speaker that completely fell off. i guess i could fix it myself but im a little lazy
May 5, 2007. 10:22 PMFenwick says:
I've gone through many pairs of headphones because of a short in the wire. Simple, but sweet instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:easycom89
YEAYY!
