3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Fix Rust Spots On a Car
Step 2Remove Paint
Remove Paint
The first thing I did was remove the paint around the rust. I used a 4 1/2" grinder with a 120 grit 3M Sandblaster wheel. It worked really well for taking off the thick layers of primer and paint. I carefully worked my way around the rust spots and removed paint until I could see clean metal surrounding the rust.
I also used that wheel for removing all of the light rust that hadn't pitted the metal.
Note: Before grinding, cover up anything that you don't want to get dusty. The paint dust is super fine and covers everything. I had my hood open to help access some rust, so I got a tarp to cover up the engine. Having your windows rolled down here would be a bad idea.
5 comments
Jul 13, 2010. 2:28 AMLeviMan_2001 says:
I wouldn't recommend using a grinder, use a wire wheel.
Apr 16, 2012. 6:05 AMJeffrey G C says:
Agreed, using a wire wheel would a better choice than a the grinder. sanding is ok, but using a grinder like is done in the next step can cause more problems than it solves. I say this for a couple reasons
1 A wire wheel wont remove too much base metal
2 you can get rust out of pitted metal better with the wire wheel than a grinding or sanding disc
However, I will caution that if you do use a wire wheel that you must wear safety glasses, and if you put the wire wheel on a drill, to always rotate the wheel in the same direction. as the wheel gets worn the wires will bend, reversing direction will cause a lot of wires to break off and go anywhere the drill is throwing them
May 8, 2011. 12:07 PMBrianJone5 says:
The sandblaster wheel is fine for this job. Its not a solid grinding disc that I think you suspected it was, its overlapping pie segments of 'sanding' material.
Mar 28, 2009. 5:59 PMxvitox says:
now what kind of grinder do you use? i am thinking about shopping for one so i can start on my acura and was wondering if you could point me in the right direction
Oct 2, 2009. 10:53 PMerick3525 says:
I use a RYOBI which is carried by Lowes...Inexpensive, but has a slot for the normally quick to vanish wrench in the handle.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:intoon
Developing projects for HowToons @ Squid Labs.
