loading
Running out of batteries when you are outdoors or may be on a trip ? A power-bank can be a life savior. But unfortunately I have broke both the ports on my power-bank
So Today I will show you how to fix such a broken USB port of any device,
So Lets get Started !
Step 1: Watch the Video!
If you don't want to read all the stuff you can watch my video on Youtube ! Click Here
Step 2: Get Into !
To fix anything it is very obvious first we have to get inside which required a lot of force and even a screw Driver which I highly don't recommend. use any other polite way :P
Step 3: Check If Broken or Poor Solder Joint
After getting into the power bank, first thing I noticed was ports were not actually broken but fallen apart because of poor/bad solder joint.
Your case might be different ! if broken You can order them from link below
http://www.gearbest.com/development-boards/pp_1333...
This is an affiliated link it helps the show.
Step 4: Disassembly
First disconnect the batteries so if anything goes wrong you will not blow up the circuit ! after which remove the PCB and remove the old Solder left on the Pads
Step 5: Solder !
Place the ports into their respective places and start the soldering process !
If you don't know the soldering process just heat the terminals using solder iron and apply the solder metal and you are done !
Step 6: Assembly
Ones soldering process is done reconnect the batteries and screw back the PCB in to its place. After which check if it works !
And it works !
Step 7: Thank You
Thank You for reading !
Feel free to check out my YouTube channel for more awesome stuff:
https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects and behind the scenes information
https://www.facebook.com/NematicsLab/
https://www.instagram.com/nematic_yt/
https://www.snapchat.com/add/nemeen
https://twitter.com/Nematic_YT
Interesting article!<br><br>Please reconsider your choice of punctuation!
About This Instructable
1,348views
30favorites
License:
Bio: Hi, I'm Nemeen !, Electronic and robotics enthusiastic. This is my channel 'Nematic !' I will be uploading on and about awesome Electronics Tutorials, Projects and ... More »
More by Nematic!:How to Fix USB Port of Any Device ! Raspberry Pi VS Orange Pi Lite Vs Up Board | Which One Is the Best ? TeamViewer on Raspberry Pi
Add instructable to:
