The way the brake pedal is connected is this: there is a rod coming out of the firewall with a hole on the end. The brake pedal has a slot on the bottom with a similar hole in it. The rod comes out of the wall and fits in the slot on the brake pedal. Then there is a hardened steel pin that goes through the hole to connect them. The problem is that the pin doesn't like to stay, and is easily wiggled out, leaving you with an unattached brake pedal.
Remove these ads by
Signing UpStep 1Remove the gas pedal
4
comments
Add Comment
Add Comment
