3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Fix Your Stereo Amplifier (Harman Kardon HK 620)
My stereo amplifier quit amplifying over the weekend. The LEDs still lit up, and it would still pass audio through the "tape out," but nothing went to the speakers. So, I decided to take it apart and see what I could find...
Step 1Open it up
Open it up
Pull the cover off, and expect to find something obviously wrong.
When there's nothing obviously wrong, make disapproving noises and have your house-mate phone his brother to see if the brother still has an extra amplifier. When it turns out he doesn't, carry on to step 2.
22 comments
Apr 12, 2008. 4:38 AMDELETED_yoghurtsniffer says:
(removed by author or community request)
Jan 9, 2011. 1:25 AMuberdum05 says:
Have you ever thought that vacuuming might pull away the static charge?
Dec 7, 2009. 12:32 AMAlesana says:
Hi , my pioneer amplifier A-443 works fine but the treble and the bass not working. And also a tick sound from inside always 10 or 15 second before another tick sound. I love to put some bass on songs but only the volume control the sound. Can you help me please.
Thanks
Alesana
Jan 9, 2011. 1:23 AMuberdum05 says:
My dad used to work for pioneer but then they went out of business in the UK so possibly could have asked him to have a look at any datasheets for it and common problems ;)
Jul 29, 2007. 8:58 PMnewtchewy33 says:
i tried it on my hk 870 but it didnt work so i put a comp fan in it and now it works... but that worked in my pre amp though so thanx.
Jul 24, 2009. 9:03 AMPunkguyta says:
Oooo HOW did you do that?? I want to mod a case fan into both of my stereos (a sony and a kenwood)
Oct 1, 2010. 5:40 PMnewtchewy33 says:
i just found a space large enough to place the fan so that it blows across inside and wired it to an external power supply.
Sep 23, 2010. 7:57 AMradium1962 says:
I know this is a joke, but come on, don't waste our time. This is a site for learning. If I want cheeky humour I'd go watch The Colbert Report.
Nov 18, 2009. 4:02 PMblahblah01 says:
i dont mean to sound, well, mean, but i dont really find this of much help, because what if dust isnt the problem for other people?
Aug 17, 2009. 10:23 PMjolshefsky says:
Could you try the following two options: 1. Open amp and put it back together. See if that works. It may be time (i.e. overheating components somewhere, or some other problem.) 2. Rather than vacuuming, flex the circuit board and components gently: things you might bump with the vacuum. If this works, it might be a cold solder joint or a broken trace or solder joint. Try heating and reflowing suspiciously dirty joints and see if that makes the problem go away for a much longer time. Good luck.
Feb 27, 2008. 10:39 AMdaveanton says:
did i miss something? Somewhere between STEP 1 & STEP 2 you: A) wired a different Amplifier in from said Brother B) did nothing And if you DID wire another AMP, wouldn't THAT be the very DEFINITION of INSTRUCTABLE? Or was this a VACUUM OUT THE RECIEVER INSTRUCTABLE? please 'splain Lucy.
Mar 16, 2008. 12:10 PMn0ukf says:
I doubt it collected enough dust in that short time to be the cause of not working. More likely, you have a loose connection somewhere that was bumped when vacuuming. Or your outputs (transistors or integrated amp modules) are going bad and can't handle the heat of normal operation any more.
And you missed a step, wipe the dust off the outer cover.
Dec 10, 2008. 1:51 AM486dx4 says:
i agree, but the dust could also have origionally caused overheating, i have an sterio amp i use for my guitar, probly built around 85, when i crank it up it starts to smell a bit kuz the dust burns, ive been meaning to take a can of air to it for a while now.
Apr 25, 2007. 5:46 AMBrennn10 says:
Same thing happens with my sister's digital camera. Dust accumulates and nothing ever works. I will definitely remember this for any problems I encounter with electronics. My, those are HUGE capacitors. -Brennn10
Jun 7, 2007. 7:27 PMKii says:
Those look like power filter caps. You really do not want to mess around with them.
May 4, 2007. 3:20 PMAeshir says:
Holy frack, yeah those are huge.
Dec 10, 2008. 1:48 AM486dx4 says:
meh those are nothing, i picked up a couple of 500vdc 1200uf caps for my coilgun project and their almost the size of pop cans, and ive seen much bigger than them.
Jan 9, 2011. 1:27 AMuberdum05 says:
I've seen capacitors rated at 2vdc and 3000F!!!!!!! they are used in the industry like in trains?!
May 4, 2007. 3:16 PMAeshir says:
My dad bought a Harmon/Kardon AVR 135 a year or so ago, just when everybody except my dad and brother (three other people in my family, including me) started to figure it out. The thing is, we never use any of the fancy controls for anything.
Apr 28, 2007. 12:14 AMmomsnacher says:
that dynaco tuner is sweet. the kits were fun
Apr 25, 2007. 4:35 PMacaz93 says:
i will repair my amp after all thanx
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
703
Author:ewilhelm
Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through understanding, and strives to inspire others ...
more »
