Introduction: How to Fix a Cracked Cheesecake
This Instructable will show you how to fix a crack in your cheesecake using hot water and an offset spatula.
Step 1: Cold Cheesecake
Start with a cold cheesecake.
Step 2: Push It Together
Push the crack together using your fingers. If it's a deep crack, push a little harder and from further away from the crack. If the cake sticks to your fingers, wet them with warm water.
Step 3: Sealing the Crack
Dip a small offset spatula into hot water. Use the spatula to smooth over the top of the cheesecake as seen on the left side of the cake in this picture.
Step 4: Finished!
Smooth over either the cracks or the whole cake as needed. The top will be slightly lighter where the inside of the cake was pulled over the top. A topping will cover this.
