How to Fix Loose Tiles
14,975
72
8
Posted
Introduction: How to Fix Loose Tiles
steps
1- prepare the surface
2- prepare the mix
3- poor the mix and fill the gape
4- finish and clean
Step 1: Collect Your Tools
white cement
some nails
steel brush
epoxy resin for concrete (optional )
Step 2: Prepare the Surface
remove any dirt
remove old joint with nails
remove any sand ,old cement under the joint by using the steel brush
it should look like clean and deep
Step 3: Make the Mix
mix the white cement
with water and epoxy solution
1 liter of water + 250 mll of epoxy
Step 4: Poor the Mix
Step 5: Clean and Put Some Weight
clean the excess white cement and put some
weights on the tale
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    8 Comments
    Damn in one of my house the flooring work is not done great by the contractor and i found the loose tiles out after days till then i released all money.
    I find your ible very useful for me and its very clear and upto the point with videos. Thanks a ton. I have one query about epoxy? from what i know, epoxy are the two part mix, and they become so sticky with almost 24hrs to cure. So are you referring the same epoxy.
    I'm glad that i could help you about your question The epoxy not the same 1 u talked about this 1 is for enhancing the concrete it's a resin epoxy it used to glue old concrete with the new concrete or make the concrete more solid
    This is an awesome idea. I have so many loose and wiggly tiles!!
    work work work
    u have 2 repair it
    specially
    if the problem on your roof
    This is a great how-to! I love how simple this is!
    ty , u r my first replay ever <3
    Is there no problem with "cement + water + epoxy mix"?
    Have that harden and bonded enough?
    u can test it hardness
