3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Floss Your Teeth
You should floss your teeth every day to reduce the incidence of tooth decay and gingivitis that leads to more serious gum disease. Here's one method that works well.
Step 1Select floss
Select floss
Research indicates that any style floss is equally beneficial for plaque removal and gingivitis prevention when properly used.
Choices include:
waxed - best for rough surfaces/restorations in the mouth that snag unwaxed floss
unwaxed - thinner, slips between teeth and under gum tissue easily, flattens out against the tooth, and makes a squeaking noise when tooth is clean
Kevlar - strong and slick, resists tearing on rough surfaces/restorations
braided - stretchy yarn-type floss especially good for large spaces between teeth
Try them and see what works best for you. The important thing is that you do floss.
34 comments
Feb 3, 2011. 2:41 PMloopytk says:
Great instructable. I feel dirty ..... I'm off to floss!
Jan 22, 2011. 6:42 AMmarichkas says:
Dec 15, 2010. 4:48 AMPhil B says:
Thank you for this. I have been flossing for decades, but not very well. Only a couple years ago a dental hygienist explained about getting down under the gum line with a sawing action. After reading your Instructable I made a more serious attempt at doing that. Even though I floss daily, I was amazed how much bleeding there was the first day. It was significantly less the second day, and has disappeared after that. My teeth and gums "feel" cleaner when I finish, too.
Dec 8, 2010. 8:46 AMpatricianorma says:
Excellent tips! Thanks!
Jun 12, 2009. 8:09 PMpie popper says:
don't you floss after you brush?
Mar 12, 2009. 8:11 AMDarren. says:
You should make another 'ible on how to floss your teeth when you have braces.
May 30, 2009. 8:18 AMfaere37 says:
Darren, use of the "floss threaders" are the most efficient type of flossing method, in my opinion, but yes time consuming. Remember though, these are your teeth-forever. Floss threaders may be purchased OTC, very inexpensive. Another product that may help is called a "Go-Between Cleaner", the very smallest brushes used on the facial parts near your brackets. There is a new product called a "Platypus Flosser", i believe you can get them on-line, same concept as the floss picks, but MADE for braces. All dental products are about efficiency, keep practicing! Also use a mouth rinse that has the keywords "kills bacteria that cause gingivitis", even if you have to get generic brands, that will help keep the bacterial load in the mouth down. Plaque forms within 20 minutes after we brush our teeth, and tartar (calculus) forms within 24 to 72 hours if we do not remove it from between or on the teeth. When you return to the orthodontist, be sure to have them SHOW you best methods for cleaning your teeth & braces, that is part of the experience. Always, Tree RDH
May 30, 2009. 8:21 AMfaere37 says:
Bob, EXCELLENT job! Tree RDH
Apr 14, 2009. 2:49 PMadidame says:
I am a dentist. This style of flossing is called the Bass Sulcular Method. Great job!
Mar 18, 2009. 6:45 PMI_am_Canadian says:
Someone needs to do this for braced teeth...
Mar 13, 2009. 5:03 AMozanozb says:
Instead of wrapping the floss around your fingers, I tie the two ends and make a circle of floss. Isn't it much easier?
Mar 16, 2009. 2:13 AMozanozb says:
Sorry if you misunderstood. I just do it this way. I'm not saying that it is the best way. I tried to wrap it around my finger but it gets wet and slips after a while. I think it works. It isn't hard to figure out. You just tie two end together and the rest is same as this instructable. Here is some visual but excuse me, I'm alone and taking the pic and holding the floss at the same time:
Mar 13, 2009. 11:15 AMDoctor What says:
Very.... ...Graphic.
Mar 14, 2009. 5:13 PMDoctor What says:
(was talking about the pictures) I'm a daily flosser as well, but unfortunately, my hands are too big to fit into my mouth to get the back of my mouth. I switched to "plackers". They're really handy.
Mar 12, 2009. 2:31 AMNachoMahma says:
. Excellent iBle! . I suspect nepotism on the Featured flag. heehee Not really. It fully deserves to be Featured. ;)
Mar 14, 2009. 7:36 AMNachoMahma says:
. Hence the nepotism remark. But I'm sure that if she hadn't Featured it, someone else would have. 100% sure - I scrolled up to Feature it but Christy had beat me to it.
Mar 13, 2009. 8:27 PMspiffytessa says:
Good job! I always have issues with controlling floss inside my mouth.. Maybe it's too small? ;)
Mar 13, 2009. 1:19 PMMarble of Doom says:
I want your nice teeth!
Mar 11, 2009. 9:22 PMalex-sharetskiy says:
Is the kevlar floss that floss that 'feels' like plumbing tape?
Mar 12, 2009. 2:48 PMEPL says:
as the son of a hygentist i know that this is a great iBle. way to floss
Mar 12, 2009. 2:27 PMLithium Rain says:
Most excellent! Here, to celebrate let's all go out for pints! Of ice cream =D
Mar 12, 2009. 1:32 PMbrothkindle545 says:
(removed by author or community request)
Mar 11, 2009. 10:38 PMChrysN says:
Great instructable, flossing makes trips to the dentist much less painful (and expensive).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Bob Canida
Hi, I'm Dr. Bob Canida. I've practiced dentistry in Madison, IN for over 30 years. My daughter Christy runs this site.
