How to Fold an Origami F-15 Paper Airplane
14,650
237
Posted in CraftPaper
Introduction: How to Fold an Origami F-15 Paper Airplane
About: Hello! My name is Joe and welcome to my instructables page! Here I will have tutorials on a wide variety of things any DIY lover will appreciate! If there is anything you want a tutorial on (preferably a sub...
Learn how to fold the amazing Origami F-15! This model is just as awesome as the F-16 and is easier to make. Watch the video above for a more detailed visual and audio tutorial, and follow along with the instructable. Anyone can learn it, and your friends will love it! So let's get started!
Step 1: Setup Folding
I'm using standard (American) printer paper, which measures 8.5 by 11 inches. First perform a "hotdog style" fold, then unfold. Next, fold the top edge down until it is about half an inch or so from the bottom edge and unfold. Now fold in the diagonals as shown. The bottom two edges should be parallel and the crease should pass through the center point. Do this in both directions, then unfold.
Step 2: Form the Base
Now we will create a modified water bomb base. Take the horizontal crease and mountain fold it strongly. Then press down on the center point gently until it pops into place. From here, grab the two opposite ends of the mountain fold and slowly draw them inwards and down. Then press the whole thing flat and finalize the creases.
Step 3: Form the Right Tail
First, move both wings off to the side just to get them out of the way. Then fold in the right edge to the center crease. Rotate the paper 90 degrees to the left, then fold the tail edge up to the top corner as shown.
Step 4: Form the Left Tail
Move both wings up to the top, then rotate the entire paper 180 degrees. Repeat the previous step on this side.
Step 5: Strengthen the Wings
Before we shape the wings, this step will make them stronger. Open the wings up so they are on opposite sides, then rotate 90 degrees to the left. Fold in the edges on both sides as shown. The folds should be very narrow but strongly creased.
Step 6: Shape the Right Wing
Move both wings over to the left and rotate the plane 90 degrees to the left. Next fold the top wing up to the point on the tail (where I'm pointing to in the third picture) so that the inside edge of the wing also forms a perfect 90 angle with the edge of the tail. At the base of the wing (5th picture) there should be a small flap. Fold it upwards and crease strongly.
Step 7: Finish the Right Tail
Move both of the wings down and fold the edge of the tail inwards as shown. Then fold the wings back up and rotate the plane 180 degrees.
Step 8: Shape the Left Side
Repeat the steps on step 6: fold up the wing as described and then fold up the bottom flap. Then repeat step 7 to finish the tail. Flatten the plane out and rotate it 90 to the left.
Step 9: Shaping the Fuselage: Part 1
Flip the plane over and you will notice two small tabs on either side of the nose. They should be folded inwards as far as possible. Then valley fold along the center crease and position the plane as shown in the last picture.
Step 10: Shaping the Fuselage: Part 2
Around 3/4ths of an inch of the way up from the bottom of the plane, Grab the top layer wing and tail and fold down parallel to the base. Crease this very strongly. Next, flip the plane over and repeat, being sure to keep both folds in alignment.
Step 11: Shaping the Plane
On this step, lift the wings up so that stay just above 90 degrees. Then use your fingernail to lift one of the top flaps up (the ones that cover the tails) and crease it to make them perfectly vertical.
Step 12: Fold Up the Winglets
Take a small portion (about 1/4 inch inwards from the edge of the wing) of the wing tip and fold it up to vertical. Do this on both wings, keeping symmetry in mind.
Step 13: The Finishing Touch
This last step may be a little tricky depending on how well you folded the plane. Those two tabs that were folded inwards on step 9 each have small pockets on them. You should be able to insert one of the tabs into the pocket on the other tab and have it stay. This will hold the plane together very well in flight, but it should be able fly without this step.
Step 14: Finished!
Now you are completely done! Have fun flying this awesome looking plane around. I hope you enjoyed this tutorial. If this seemed easy to you, you should definitely check out my tutorial on the Origami F-16 (or any of my other tutorials). For even more origami, click here to check out my Youtube channel and if you like it, subscribe to show your support! Keep on folding!
  • Trash to Treasure
    Trash to Treasure
  • Spotless Contest
    Spotless Contest
  • Space Challenge
    Space Challenge
