3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Forge a Throwing Knife
Step 3Make the Loop
Make the Loop
  • G:\DCIM\100HP715\IM000836.JPG
  • G:\DCIM\100HP715\IM000837.JPG
  • G:\DCIM\100HP715\IM000838.JPG
  • G:\DCIM\100HP715\IM000839.JPG
To make the loop on the end of the knife, i bent the steel. A lot. I know it's fairly obvious that you'd have to bend the steel to get bendy steel but i just needed to say that. Start by drawing out about 4 inches of the file. To draw out steel, heat the bit you want to work to forging heat and hit it on one side, then turn it through 90 degrees and hit it some more on the other side. you reduce the width and depth but increase the volume. Draw it out till its about 3/4 its original thickness. Once you've drawn it out, you'll need to bend it through 90 degrees, so it looks like the first picture.
For the next step of the bendening, you'll need to make a quwstion-markish sort of shape, by bending it around again.
Now comes the tricky part, you'll need to get inside the flat bit and bend that over too. My best advise is Be Creative.
Finally in this step, finish the bendification by pushing the end of the steel over to meet the main part of the bar. After that, I hot-cut off the rest of the file, that I hadn't ground so it was smaller and easier to work with. Now its about 6 inches long with a loop on the end.
3 comments
Mar 1, 2010. 1:26 PMicecoldcelt says:
It may be late to comment, but I find it to be much easier to start from the other end of the loop, making it curl like a finger and then making the 90 degree bend with the loop through the horn.
Sep 14, 2007. 4:10 PMCorrbrias says:
Looks like a tent stake. You can buy tent stakes here: http://www.campmor.com/webapp/wcs/stores/servlet/CategoryDisplay?categoryId=7310&storeId=226&catalogId=40000000226 and they're a lot cheaper than files.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:Vendigroth
I shouldn't have to tell you that using a dagger to undo this little, fiddly screw's a bad idea. AAAAARGH! big project ^^ so practically no chance of instructables from me till july, p'raps? maybe a...
more »
