Step 5Grind it to Shape
If you want to do it by hand, use a vice and a file. Have fun in your toils, I wish you well! Personally, I believe that tools are made to be used. That's why i'm using my bench grinder to take away all the excess steel. This beast bites deep and does it quickly. One moment's lack of attention could have you looking on the floor for your fingers or, even worse, could completely mess up your knife! porceed with caution. Once it's been ground to shape, you should set about removing the grind lines. THIS is where I recommend a file, and a fine one at that. Again, proceed carefully. After the file, I moved on to a coarse waterstone.
I know for a fact that the best way to proceed is to get most, if not all of the necessary shaping and grinding out of the way before heat-treating the steel, I mean, why make extra work for yourself?
4
comments
Add Comment
thoraxe
says:
thoraxe
says:
Add Comment
