Introduction: How to Foundation Double Crochet
Picture of How to Foundation Double Crochet
Do you suffer from tight crochet foundation chains? Do you love beautiful crochet edges that are stretchy and elastic? Then you are going to fall in love with the Foundation Double Crochet technique!
Not only does it give you a foundation chain with ease…you create your double crochets at the same time!
No more puckered edges or unforgiving tightness! This is great for sweaters sleeves, hats worked from the brim up, or anything you want to have a nice stretch.
Watch the video below or follow the photo tutorial or both!
Step 1: ​Begin by Making a Slip Knot and Placing It on Your Hook
Picture of ​Begin by Making a Slip Knot and Placing It on Your Hook
You can see how to make one on my tutorial How To Make A Slip Knot.
Step 2: Chain 4
Picture of Chain 4
Step 3: Yarn Over
Picture of Yarn Over
Step 4: Insert Hook Through Center of First Chain. (4th Chain From Hook)
Picture of Insert Hook Through Center of First Chain. (4th Chain From Hook)
Step 5: Also Insert Hook Through Loop on Back, Slightly to the Left
Picture of Also Insert Hook Through Loop on Back, Slightly to the Left
Step 6: Yarn Over
Step 7: Draw Back Thru
Picture of Draw Back Thru
Step 8: You Now Have 3 Loops on Your Hook
Picture of You Now Have 3 Loops on Your Hook
Step 9: Yarn Over Again
Picture of Yarn Over Again
Step 10: Draw Hook Back Through First Stitch Only
Picture of Draw Hook Back Through First Stitch Only
Step 11: Yarn Over
Step 12: Draw Back Through 2 Stitches
Picture of Draw Back Through 2 Stitches
Step 13: Yarn Over Once More
Picture of Yarn Over Once More
Step 14: Draw Hook Back Through Last 2 Stitches
Picture of Draw Hook Back Through Last 2 Stitches
Step 15: A Finished Foundation Single Crochet
Picture of A Finished Foundation Single Crochet
Step 16: ​Continue Working, Starting Each Repetition by First Yarning Over, Then Insert Your Hook Through the Foundation Chain Previously Made
Picture of ​Continue Working, Starting Each Repetition by First Yarning Over, Then Insert Your Hook Through the Foundation Chain Previously Made
Then repeat steps 5-12, for each stitch you want to create. Your foundation chain will be the chain you just made, and is to your left. In the photo above, it is the highlighted blue chain, not the green.
Step 17: Once You’ve Done Several Repetitions, This Is What Your Foundation Chains Will Look Like (in Green)
Picture of Once You’ve Done Several Repetitions, This Is What Your Foundation Chains Will Look Like (in Green)
Step 18: This Is the Anatomy of a Foundation Double Crochet. You Can See Where Everything Forms!
Picture of This Is the Anatomy of a Foundation Double Crochet.  You Can See Where Everything Forms!
You will make this differently than when traditionally crocheting, where you work from the bottom (foundation chain), and work into each chain. Each foundation chain and double crochet are made at the same time…so you work sideways!
Step 19: Tip: Always Insert Your Hook Through the Stitches All the Way Back to the Shank or Shaft of the Hook. You Want the Width of the Shank to Push Through, Otherwise Your Foundation Chains May Be Too Tight.
Picture of Tip:  Always Insert Your Hook Through the Stitches All the Way Back to the Shank or Shaft of the Hook.  You Want the Width of the Shank to Push Through, Otherwise Your Foundation Chains May Be Too Tight.
Step 20: That's It!!
Don’t worry if you don’t get this at first, just keep practicing and you will understand it quicker than you think! Let me know if you have any questions in comments below!
Keep on Crafting!
sloyt64 (author)2015-08-26
All i can say is thank you so much this helps in so many ways.
CreatiKnit (author)sloyt642015-08-26
You are so welcome sloyt64! I am so happy it was helpful to you! :)
marceec made it! (author)2016-10-28
I'm making a lacy cowl. This foundation is more time- and yarn-consuming than a plain foundation chain, but it's also more elastic and feels like it'll hold up better over time as an edge for the more delicate lace pattern of the cowl. Thank you for the tutorial.
imerrymary (author)2015-10-31
I'm starting to crochet again after several years and luckily I found this 'ible that solves a major problem. It was frustrating to have that tight foundation chain ruin the symmetry of a project. Thanks SO much. I'll never do a simple chain foundation again.
sunshiine (author)2015-09-05
I would love to make a hat using your instructions~ They are simple to follow.Thanks for sharing.
sunshiine~
CreatiKnit (author)sunshiine2015-09-05
So happy you love it Sunshiine! :)
About This Instructable
4,150views
139favorites
License:
Bio: Creatiknit.com ♥ Knit & Crochet designer ♥ Blogger ♥ Mom ♥ Tea drinker with a flair for all things whimsical & woodland ♥ Hi, I'm Angela, and I am the ... More »
More by CreatiKnit:How to Front and Back post double crochet (FPDC & BPDC)How to Foundation Single Crochet!Learn how to Double Crochet
Add instructable to:
