How to Get Diamonds in Survival Minecraft
55,280
10
14
Published
Introduction: How to Get Diamonds in Survival Minecraft
About: I like food and art. Don't mind my weird instructables.
Hello, in this instructable, I will be showing you how to get diamonds in survival mode of Minecraft.
You will need:
An Iron or Diamond pic ax
A mine going down to bedrock
Please enjoy.
Step 1: Tunneling
When you make a mine, the best way I know to efficiently get down is to make a staircase mine. How to make one? all you need to do is mine three down in front of you when in the ground.
Step 2: Layers
Once you get to bedrock, dig out a little area to find the highest bedrock block. Then, when you have found it, go five meters(blocks) higher and make a straight tunnel.
Step 3: Diamonds
Keep tunneling until you find some. I hope you found this useful. Please vote, and comment.
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    14 Comments
    Nice! The most I've gotten was about 48 diamonds in about 3 days.
    don't forget to bring crafting tables!
    i always go down in creative difficulty set to peaceful so there are no hostle mobs.Then,i switch to survival and mine.
    Fastest safe way of mining downwards: Stand on between two blocks on the surface. Then, below you, destroy the left and the right, the left and the right, the left and the right... If you stand in the middle enough, you won't fall down if spotting lava below a block you destroy. Make sure to make yourself a full stack of ladders so you can get to the surface again right after mining.
    the easiest way to dig down ward is to make a bunch of ladders and go straight down. it makes going back up and down really fast and easy.
    if you go straight down you will hit a bunch of caves and die. :C
