3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Get Rid of Ants (Outdoor Version)
This is a modified version of this link. I do not claim this as my original version, but this is how I made mine so I could put them outdoors where my ant problem is/was.
Safety Note! This is very important, so I ask that you please pay attention to this before performing this Instructable. Borax, while used in many things as a helpful additive is a very nasty poison. This instructable assumes that because you now know this you will conduct yourself accordingly. I did some research and have found that one spoonful of this stuff *will* kill you. Half a spoonful is enough to kill a child or small fuzzy animal. So I ask that you please be responsible while making this instructable and keep track of what else is eating it. If you make some Borax Jelly and eat all of it, I am not responsible. After all, the box tells you not to, and I've advised against it so you're on your own if you keep reading!
On a better note....
Update: Rained all day and jelly stayed where it should have! But I do not know if the solution was diluted or not. Will keep this updated as things go by.
Step 1What you will need
What you will need
The materials for this project are easy to come by, and can be bought or obtained for free.
You will need:
1x Box of Borax
1x Jar of cheap Jam/Jelly/Preserves
1x Empty water bottle. (Mine was a 1litre water bottle)
1x Plastic Spoon
1x Hammer
1x Sharp knife or Scissors
4x Roofing Nails
4x Bottle caps
Safety stuff:
Goggles, chemical gloves, working gloves.
38 comments
Apr 1, 2008. 10:58 AMadmin says:
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
Mar 27, 2011. 1:32 PMbthorne1 says:
I just throw corn meal down on //near ant hill or openings and they are killed off and no other ill effects. Much safer for other animals.
May 5, 2010. 8:15 AMBirdy Jane says:
 I've read that ants loosely fall into one of two categories: they are either 'sugar ants' or 'grease ants. A sugar ant will go for your jelly or syrup or any sweet substance, while the grease ant is attracted to the savory.
I've read that in many places so it must be true. It must also be true that the ants at my house are a rare or even unique species as they are utterly inconsistent in their tastes. They seem to be attracted to anything that might piss me off.
A few years back I bought pure borax. I meant business. But I chickened out from using it, the warnings, like yours, were just too scary for me. The bottle still sits on the highest shelf in my laundry room.
I've come to realize that as long as I have a maple tree with aphids, I'll have ants (they actually nurse, or farm the aphid stock to keep themselves in aphid honey) I just don't get why they won't build their nest(s) in or under the tree instead of under my siding.
Aug 7, 2010. 7:43 PMGalonii says:
i use tuna oil, the oil you drain from your can of tuna before eating it
Jul 18, 2010. 9:56 PMWolfWoof20 says:
From Wikipedia:
Based on mammalian median lethal dose (LD50) rating of 2,660 mg/kg body mass, boric acid is poisonous if taken internally or inhaled in large quantities. However, it is generally considered to be not much more toxic than table salt.[4] The Thirteenth Edition of the Merck Index indicates that the LD50 of boric acid is 5.14 g/kg for oral dosages given to rats, and that 5 to 20 g/kg has produced death in adult humans. The LD50 of sodium chloride is reported to be 3.75 g/kg in rats according to the Merck Index. Long term exposure to boric acid may be of more concern, causing kidney damage and eventually kidney failure (see links below). Although it does not appear to be carcinogenic, studies in dogs have reported testicular atrophy after exposure to 32 mg/kg bw/day for 90 days. This level is far lower than the LD50.[5] According to boric acid IUCLID Dataset published by the European Commission, boric acid in high doses shows significant developmental toxicity and teratogenicity in rabbit, rat, and mouse fetuses as well as cardiovascular defects, skeletal variations, mild kidney lesions.[6] As a consequence, in August 2008, in the 30th ATP to EU directive 67/548/EEC, the EC decided to amend its classification as reprotoxic category 2 and to apply the risk phrases R60 (may impair fertility) and R61 (may cause harm to the unborn child).[7][8][9][10][11]
Jul 18, 2010. 10:00 PMWolfWoof20 says:
Just to make sure you all read that...:
So yea, maybe not that bad, buy do have a care! It seems it can have some adverse health effects long before death.
Aug 26, 2009. 7:13 PMREA says:
is that a picture of a Trojan ant?! i dont think that old plan will work on them.
Jul 14, 2009. 9:38 PMakayaker says:
Actually i like the photo where you have the nail half way through the cap. If you use a longer nail the upper half would provide a nice little handle to push them into the ground with. This would eliminate your need for a stick (step 5) to push the baits into hard earth.
May 17, 2008. 6:12 PMbowmaster says:
How to get rid of ants in one word: Flamethrower.
May 15, 2009. 4:58 PMdiegolay says:
or put some gasoline in and near the ants nest, then throw inside a lighted up match
Apr 27, 2009. 11:51 AMlilykoart says:
only if you can reach the queen :) otherwise you get only the worker ants.
Apr 27, 2009. 12:33 PMbowmaster says:
It heats up the ground enough to kill it even if you don't actually burn it.
Apr 1, 2008. 1:48 PMrusty13jr says:
HOLY 1337 ANT KILLER!....too bad your 1336 <()>
Apr 29, 2009. 9:56 PMMozonTheGreat says:
OMG!! Deadly Ants
Apr 17, 2009. 10:35 AMmerijnvw says:
Borax isn't that poisonous, the the highest dosis for a 80 kilogram person is 400 gram, so kitchen salt is more poisonous.
May 4, 2008. 12:42 AMPuffin Stuff says:
wow, i dont know where your info is coming from, borax will not kill u or small animals or children w/ the amount you are talking about.. i have been consuming 1/8th teaspoon of borax diluted in a quart of water.. actually i use green tea.. and i consume more water thru the day etc.. for the last 3 years.. my skin is healthy, my hair is soft, my feet are fungus free, and my digestion at age 42 is that of a 17 yr old.. i eat hot peppers, cucumbers, onions etc on a regular basis w/ no heart burn what so ever..borax is in bath crystals, edible plant pesticides, eye drops and various other things that a simple google search would illuminate you to.. also see this website http://www.earthclinic.com/Remedies/borax.html
and expand your horizons..
Oct 16, 2008. 1:03 PMBorat says:
Do you use 20 Mule Team or pure borax?
Oct 16, 2008. 2:35 PMBorat says:
I asked because on that link you posted some people reference pharmaceutical-grade, pure borax. I have the 20 Mule and it says "not for drug use" apparently because it also contains surfactants and other laundering aids. I guess in these concentrations they don't harm you, though. Thanks again for the great tip.
Apr 2, 2008. 4:30 PMwocket says:
beware of pets, wildlife and small children eating this stuff. Borax works by causing a solid blockage in the digestive tract and is a very painful and slow death.
Apr 4, 2008. 4:52 PMwocket says:
it takes just half a teaspoon to kill a human, so much less for small fluffy creatures.
Apr 5, 2008. 4:11 PMwocket says:
Not a link but I used to layout info from a medical research facility before the papers went into the general public and I remember reading it there. Scary stuff.
Jun 21, 2008. 10:13 PMmce128 says:
Well this is scary then... (from Wikipedia) Food additive Borax is used as a food additive in some countries with the E number E285, but is banned in the United States. Its use is similar to common table salt, and it appears in French and Iranian caviar.
May 17, 2008. 6:16 PMbowmaster says:
Ninja never type the last phrase replacer you typed. They type YWDTBMH (You Will Die Tomarrow By My Hands)
Apr 30, 2008. 7:41 PMStopher says:
I'm going to have to disagree with any person that says half a teaspoon is as heinously toxic like botulinum. I mistook borax for non dairy creamer in college (the pure stuff for killing roaches). I drank several table spoons and it would just not mellow the taste of the coffee so I added more. After two days of the runs, I told my room mate that his creamer had gone bad. He informed me he had no creamer, but did have one of the huge wal-mart containers of borax for killing roaches under the sink with the other poisons. I called poison control and they said it was usually only a problem with children and that was the cause of the runs. They said it was not so toxic as to get too excited. I'd have had to eaten cups and did not need to go to the hospital. Perhaps you are thinking of BORON instead of the compound Borax. I'd have to look up the properties of each in the chem hazard book at work to give a real definitive answer. Remember SALT carries tons of crazy warnings about how it can elevate blood pressure and irritate wounds and sting mucus membranes and dry / irritate skin. Some of the warnings are just silly and hard to get a real idea about.. Borax is not very toxic to humans except for children.
May 1, 2008. 5:15 AMwocket says:
I just confirmed with my researcher friend at Qld Medical Institute and they confirmed that it is quite dangerous... mostly for causing blockages in the gut. So you still need to be careful of pets, wild animals, children and ..well..anyone. :) Stopher, I guess we'll just agree to disagree.
May 25, 2008. 11:45 PMGrey_Wolfe says:
I might suggest that you place several small (half teaspoon, maybe) samples of foodstuffs (sans borax) in a location that is readily noticable to your ants. See which ones they respond to best and then alternate your bates between these items. Hope this helps. At least it would save you the trouble of making poisons that don't work.
May 14, 2008. 4:20 PMJeremyA says:
If you see the ant hills in your yard all you have to do is poor boiling water down them and that should take care of it. If needed repeat the steps more than once or every so often when you find a new one. I imagine it is a pretty terrible way to die but that is your choice.
Apr 17, 2008. 8:52 PMEstwald says:
If you're beset with only the brittle type of caps drill the hole in the cap instead of punching it with a nail. -Ray-
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:The Dark Ninja
