How to Get/Convert HEX File From .ino File of Arduino Sketch
Published
Introduction: How to Get/Convert HEX File From .ino File of Arduino Sketch
About: Electrical engineer by profession
Hello friends.
Here i want to share How to convert Arduino Sketch from .ino format to HEX format & how to upload it on Arduino using XLOADER
When we are using XLOADER application to upload sketch to Arduino we need Sketch file in HEX format.
This is very simple just follow mention steps and you can watch video for better understanding (recommended)
1) Press "WIN+R" to open Run Command
2) Type "%TEMP%" & press enter
3) Select all item and delete them, some of them can't delete skip them go back to desktop
4) Open Arduino IDE application
5) Now open sketch of which you want HEX file here i am using "BLINK" sketch as a example
6) Now do Complie and after compling close arduino IDE
7) Now again press "WIN+R" to open Run command and type "%TEMP%" & press enter
8) Now type "HEX" in search tab in result you get recently complied sketch in HEX format copy it and paste it where you want
9) Now open XLOADER
A) Select HEX file to upload B) Select your Board C) Select COMport D) Keep Baudrate unchange
10) Now justb click on Upload button so HEX file will upload on Arduino
Step 1: General Requirment
Following are the item you required
1) Computer system with Windows
2) Arduino board & cable
3) Arduino IDE
4) XLOADER application
Link to download XLOADER
http://russemotto.com/xloader/XLoader.zip
Thanks for your attention
Any suggestion/Comments/Query are welcome
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    3 Comments
    OR
    you can use file > preferences > show verbose output during compilation (Check)
    verify your code
    scroll to the bottom of the output (assuming a successful build), and get the location of the file that ends with .hex
    in my case, it was something like
    C:\Users\Meena\AppData\Local\Temp\build7741102908600848800.tmp/sketch_oct09a.cpp.hex
    i believe you can directly paste that path into XLoader, and save some time searching for the right file
    Thanks for this input as this is a very basic guide prepared by considering that user is beginner so I avoid including complex stuffs
