Introduction: How to Go No Poo
To go No Poo is to stop using shampoo. Why would you want to do this?
1. Shampoo is expensive.
2. Chemicals* in shampoo can irritate and dry out your scalp and hair.
3. Chemicals* in shampoo can be hazardous to your health.
4. Your body produces oil to naturally condition your hair and keep it healthy. Using shampoo daily upsets the natural balance and causes you to produce more oil than necessary to compensate.
When you stop using shampoo, you will probably experience a transitional period while your body gradually adjusts to produce just enough oil to keep your hair healthy. During this time, which can range from a few days to a few months, you'll probably have some extra oil and grease that you may want to take care of to look presentable. The cheapest and most effective way to handle this is to use baking soda. The method I use involves a plastic cup, some baking soda, and a shower. You may also want to condition your hair after using the baking soda mixture, as sometimes it can leave your hair a bit dry. There are lots of different ways to do this; I use apple cider vinegar.
* In this context I'm referring to certain synthetic chemicals which have proven harmful in specific circumstances. I'll let you look up each one in the ingredients on your shampoo on your own. Your shampoo might not have anything you don't like in it after all, although the other benefits of going no poo still apply. Please keep in mind that literally every substance can be referred to as a chemical and many are not generally harmful (water, for instance).
Step 1: Cleaning
Step 2: Conditioning
Step 3: Closing Thoughts and Advice
The eventual aim of this process is to let your natural oils care for your hair, so you should use the baking soda and vinegar only as much as you need it, hopefully reducing your usage to zero eventually. Good luck, and don't give up!
