To go No Poo is to stop using shampoo. Why would you want to do this?
1. Shampoo is expensive.
2. Chemicals in shampoo can irritate and dry out your scalp and hair.
3. Chemicals in shampoo can be hazardous to your health.
4. Your body produces oil to naturally condition your hair and keep it healthy. Using shampoo daily upsets the natural balance and causes you to produce more oil than necessary to compensate.
When you stop using shampoo, you will probably experience a transitional period while your body gradually adjusts to produce just enough oil to keep your hair healthy. During this time, which can range from a few days to a few months, you'll probably have some extra oil and grease that you may want to take care of to look presentable. The cheapest and most effective way to handle this is to use baking soda. The method I use involves a plastic cup, some baking soda, and a shower. You may also want to condition your hair after using the baking soda mixture, as sometimes it can leave your hair a bit dry. There are lots of different ways to do this; I use apple cider vinegar.
Step 1: Cleaning
Put 1-2 tbsp of baking soda into a 16oz cup (or close). The ideal ratio is about 1 tbsp of baking soda per 1 cup of water. When you get in the shower, fill the rest of the cup with water and stir until the baking soda is dissolved. You should have some cloudy water at this point. If the mixture feels gritty or pasty, either add more water or use less baking soda. Now apply the mixture to your hair. Ideally, you should aim to get most of it around your roots and work it in with your fingers, gradually distributing it throughout the rest of your hair. It won't lather like shampoo, but it does give your hair a distinct "smooth" feeling when it's properly distributed. Once you've rubbed it around a bit, you should be ready to rinse. When you are completely rinsed you are ready to condition.
Step 2: Conditioning
The simplest way to condition is to use apple cider vinegar, in about the same way as you used baking soda: 1 tbsp of the vinegar per 1 cup of water. If you like you can add a few drops of your favorite essential oil, some honey, or some lemon juice. When you've mixed up your conditioner, pour it on and work it in just like you did the baking soda. When you're satisfied, rinse thoroughly.
Step 3: Closing Thoughts and Advice
I hate the smell of vinegar. However, apple cider vinegar isn't as harsh as white vinegar, and after you rinse and dry your hair, the smell is completely gone. Your hair will smell like hair, or maybe whatever you added to your conditioner.
The eventual aim of this process is to let your natural oils care for your hair, so you should use the baking soda and vinegar only as much as you need it, hopefully reducing your usage to zero eventually. Good luck, and don't give up!
What are they? Dihydrogen monoxide and silicon dioxide. Both of these compounds can be very, very dangerous, even kill you. Use wisely.
You'll find using diluted lemon or vinegar rinse works well, it helps to smooth the hair cuticle making it slippery & less tangled. I hope this helps!
In addition you can make your own conditioner so much more cheaply than buying it. I like this one: http://www.instructables.com/id/Eco-friendly-low-cost-hair-conditioner-and-gel/
My hair is curly and, therefore, dry and this conditioner has done wonders for my hair this winter. My hair usually doesn't curl in the winter, it just dries out and frizzes no matter what I used. But with this home-made conditioner it has been soft and curly.
The outer layer of the hair, the cuticle, can be raised by heat and changes to elevate pH. The natural pH of your skin, hair, and nails is 4.5-5.5 on a scale of 0-14. Shampoos and soaps are more alkaline in nature, falling above the "neutral" 7 marker. This means that the sulfates (detergents) in these things, like that lovely smelling Pantene ProV shampoo in your shower, or your "antibacterial" soap (ALL soap is antibacterial) attach to the unwanted molecules so that the grease and dirt can all be pulled out of your hair and rinsed away. Sadly. these harsh chemicals don't discriminate. They strip your natural oils too. (I'm not going to go into health effects because I'm not qualified to do so, but I don't exactly think they're terribly healthy either.)
So your cuticle is raised, right? All the dirt is gone and you can just get your happy self out of the shower and everything will be okay? Wrong. You must CLOSE your cuticle, or your hair will be dry, probably very brittle, straw like, and break very easily. All because you chose to leave it's natural defense system open.
This is where the acidity of the ACV comes in. Or, you can use lemon juice, lime juice, or anything else nontoxic that is gentle enough to use, or that you can dilute to be so. Oh, hey, did you know that a lot of people rinse their hair in beer? (: I don't necessarily think it's the hops and barley that women (and even men) enjoy so much that makes their hair so soft and shiny. It's pH? 4.5 :D
So, my suggestion would be, (if you're 21 that is) buy yourself a 12 pack, and make yourself a deal. Before or after your shower (which, shouldn't involve cleansing your hair more than 3 times a week), take a mental health break and drink a beer, and use one more on your hair. And, notes to any other ladies out there reading this, I think it's a beer a week can help to prevent yeast infections. Win-win-win? I think so.
I hope this has helped. I'm an aspiring cosmetologist (which is why I have all this information. That, and I'm addicted to knowledge), so I thought knowing the ins and outs of the process might be useful. :)
Thank you for saving me alot of pain in my ear! :)
Ones diet also has a big effect on hair, so if nothing seems to be working, maybe making a change in what you're eating could help out. I notice that when I get all of my minerals and vitamins, my skin and hair and nails are much healthier than when I'm too tired to prepare food and eat processed stuff.
Also, when starting out, you may want to do this before a gentle shampoo, depending on what condition your scalp is in when you start up and how much dander you break loose and how much oil gets freed into your hair.
After cleaning your hair with the brush, it's a good idea to clean the brush before doing the "100 strokes" (I used two brushes when I had long hair, stiffer for cleaning).
Once your scalp is healthy, from time to time when there is too much oil in your hair, instead of a shampoo, you can brush a little baby powder or talcum powder thru your hair during brush cleaning.
Factors that may alter your usual routine are how much your scalp was sweating and how much dust or floating debris from the environment got in your hair.
In effect, your healthy scalp and hair become a micro environment where conditions vary by days, activities, and seasons, and your grooming adapts to those conditions, including when it's time to wash it.
Don't confuse the above with detangling your hair for whatever reason (see next post) and do trim your split ends.
kingsdaughters21.blogspot.com/2012/01/natures-way-experiments.html
I've tried commercial hair shampoos to solve my dandruff problem which I previously thought was attributed to fungal infections, but it turns it out it's because the shampoo I used (Herbal Essences -.-) was incompatible with me and simply destroyed my skin.
So I tried sodium bicarbonate today. I was a little freaked out by the fact that I dropped a lot of hair during the wash compared to mild commercial shampoos like Simple. Also, after rinsing, while it was still wet it felt rubbery, I guess it's too strong a cleansing agent. When my hair was still wet it felt really horrible, so I conditioned my hair with a leave-in silk conditioner and now that it's dry it seems fine.
I'll try this again, if not because I skipped the ACV then because I think it's worth tweaking and giving a second shot. I'm not going back to commercial hair shampoo. If anyone has any other natural remedies to recommend for my problem (flaky dandruff, increased hair fall with harsh chemicals including NaCl) don't hesitate to let me know!
Again, thank you for posting your instructable, it was really helpful.
I loose lots of hair when I shower usually, but it doesn't show, hair falls to leave place for newer ones if they fall at a normal rate. As long as you don't see chunks of hair falling down I think you'll be fine.
If the ratio is still too high for your hair, you might wanna adjust it. Try different quantities, find you own. I tweaked mine and I find it to work quite well. About half a cup of baking powder in a pitcher of water, pour that stuff over you head when you shower, leave it in as long as you want, longer the better according to me, rinse that out, there ya go.
is this true?
I actually stumbled across this no-poo thing while searching for seitan recipes, if you can believe that.
I have some questions tho, and a lot of blogs i find are conflicting on the exact way to do this.
I color my hair with semi-permanent pigments on a regular basis, and am sick of my city water and shampoos stripping the colors away after a week. Although the dye doesnt effect the strength or moisture of my hair, it's still annoying to have to recolor it so often, even with color safe shampoos, specifically made to protect the colors.
I have had a few people say that this baking soda method doesnt effect coloring.
I want to know if this is true. I havent seen any actual reviews concerning the condition or length of color vibrancy.
I also have seen conflicting reviews and instructions on conditioning. Some people say it is absolutely necessary to use the vinegar, while others say you can just use lemon juice. I would prefer lemon juice, but would it actually work the same? and what would the effect be on my color?
i already skip multiple days between shampooing. most times i just rinse it while im soaping up the rest of myself. im thinking this would be a pretty easy transition. im just worried about the state of my color.
i want to know, specifically, if anyone has used this method with colored hair over time, and what the results were.
and also what other methods there are to using vinegar, if there are any.
