Step 3Figure Out Where to Plant Pineapple...
For the planting itself, I have found that putting the pineapple top directly into the ground works best. There are other techniques to planting pineapples, such as trimming all of the remaining fruit away leaving just the base of the leaves, then letting the top dry out for a few days, then putting the pineapple top in a glass of water until roots start growing, then finally planting the pineapple top into the ground. I have experimented with these extra steps and haven't had too much luck. Trimming all of the fruit away just seems to kill the pineapple plant, even before it is planted. Root sprouting in water resulted in some very moldy pineapple plants, which ended up no surviving. So with all of these extra steps that you could try, sticking the pineapple top directly into the ground seems to work best.
If you live in a warmer climate, you can plant your pineapple directly into the ground. Where I live, there is an occasional frost each winter, but that's about the worst of the cold weather. My pineapple plants handle that just fine. If your winter weather is any worse than the occasional freeze, plant your pineapple in a pot where you can take it inside.
When you pick out a spot (or pot) for your pineapple, make sure it has room. The plants grow to about five feet across and get spiny leaves, so take that into consideration when deciding where you plant your pineapple.
Pineapples DO produce seeds, and the seeds from MOST are viable. Pineapples will usually produce fruit a second time but not usually a third.
The "pups" at the base of the fruit can be replanted, so it is common to get 2-3 new plants out of every old one.
Good catch there.
