3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Hack Microwave Popcorn
I was watching a movie while eating some popcorn one day and I thought to my self, why cant they manage to put enough butter in this popcorn? Then I thought I could just melt some butter and pour it over the top, but then I would just end up with some soggy kernels. It didn't take long for me to realize that I would get an even distribution of butter, and no soggy kernels, if the popcorn was popped with the butter, just like it already does inside a bag of microwave popcorn.
So I pulled out a tupperware bowl, a bag of microwave popcorn, and a stick of butter. I quickly tore open the bag of popcorn and dumped it into the bowl along with a lump of the butter. I snapped on the lid, leaving a small portion unsnapped so that steam could escape, and punched in 4 minutes on the timer. As the end of four minutes neared, I began to worry as I have only heard a few pops, no where near as many as there should have been. So I removed the bowl from my microwave and set it on the counter. Just then, I realized that the bottom of the bowl had melted away and poured liquid butter all over my counter. Needless to say, that was a complete and udder failure. On the bright side, the few kernels that did pop tasted delicious.
But all is not lost, I had had another idea. Why not just slip in some extra butter into the bag itself? That is exactly what I did, and I'm proud to say it worked perfectly.
The following are the steps I took to hack into a bag of bland microwave popcorn and make it into delicious super buttered popcorn.
You will need:
1 Bag of your favorite microwave popcorn.
1 Roll Masking tape
1 Knife (butter knife will work fine)
   Butter
   Favorite Popcorn Seasoning
Step 1Cut open bag
Cut open bag
First you need to open up the bag of popcorn from its plastic packaging, and lay it out flat.
Then you need to cut a flap with your knife (butter knife will work because the paper is somewhat brittle). Start at the middle along the seam of the bag and cut towards the edge, stopping a half inch before you reach it. Then cut a similar line 2 or 3 inches apart from the first. Connect the ends of each cut at the ends nearest the edge. You should end up with a flap like shown in the pictures.
9 comments
Dec 28, 2010. 10:20 AMCaseyCase says:
Mmmm! Cooked tape flavor!
Oct 30, 2011. 9:38 PMsiamonsez says:
That's just what I was thinking, yummy tape glue.
Dec 28, 2010. 9:40 AMBrowncoat says:
Instead of cutting a hole in the middle of the bag, why not just cut open the top of the bag & tape it back up? Seems like it would be a bit easier with the taping.
Feb 22, 2011. 1:45 PMParacord Ninja says:
That is a very cheap and good way to make popcorn
Dec 29, 2010. 7:09 AMjhines0042 says:
Nice idea. Here is a way to save money while also adding (or removing) butter or other seasonings. http://www.instructables.com/id/Microwave-Popcorn%3A-Home-made,-cheap-and-easy/
Dec 29, 2010. 1:02 AMNatNoBrains says:
Nice idea!
Dec 27, 2010. 6:18 PMtocsik says:
I just tried this out and it worked like a charm. Next time I'll add even more butter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jblanke
