How to Hide a Stinky Cat Box
9,707
259
11
Published
Introduction: How to Hide a Stinky Cat Box
About: Hi! My name is Curtos, nice to meet you. I have been an Instructables member for a long time now. I am a YouTuber and a humble Maker. I really just like to make things. Reach out to me, I am a talker! Cheers
This may not be your typical hiding places instructable, but different is good! I am hiding the nasty stinky cat boxes in the garage so our guests don't have to smell the foul smell of cat excrement. I also didn't want the cats roaming around our garage so this is how we hid them. No more stinky house or garage!
This is just a guide to help you along since almost every situation this will require a custom build.
Here are the things I used
  • Wood for the box to be made
  • A flap for the cat tunnel
  • An automatic light switch
  • LED bulb
  • Small Desk fan or computer fan
  • dryer duct
  • exterior dryer fitting
  • aluminum sticky tape
  • hinges
  • a clasp to hold the lid down
  • sealant
  • silicone
  • weather stripping
  • cat poop boxes
  • paint
  • wire
  • light fixture
  • lots of patients
Step 1: Make a Box
I chose to repurpose some plywood that I found when we bought our house. It was a horribly designed bench that was quite useless. I sanded all of the parts that got wood glue. I attached everything with wood glue, clamps, and screws. Make sure that the box you make is sturdy and strong.
Step 2: Seal the Box
I still use my garage so I didn't want to just make a cat door and put kitty litter boxes loose in the garage. So sealing this is the key to getting the funk out your house yo! I applied a foam weather stripping as well as using silicon to seal the inside. I also sprayed the inside with a sealant which I didn't get a picture of.
Step 3: I Don't Scoop the Poop (My Wife Loves To!)
I don't actually have to ever clean out the cat boxes. Pretty sweet deal huh? I wanted to make this very easy for my wife since she is the sole user. I added hinges for the lid. The front has two simple latches that pull the lid down with pressure to help complete the seal.
Step 4: Custom Adapter
I repurposed this container to adapt the vent to the box. I also used a computer fan to push the air. I cut the bottom off using my scroll saw. Also cut a hole in a piece of wood to accommodate for the fan.
Step 5: Adapt
I am adding the parts to my custom adapter. If you can find off the shelf parts to replace this steps, I highly recommend doing so.
Step 6: More Adaptation
I finished out the adapter that I created. The photos speak for themselves.
Step 7: Exhausting Vent
I went frugal and it paid off quite handsomely. I used an off the shelf dryer vent to route the stinky air outside. It works great and the smell goes where it needs to go.
Step 8: Let There Be Electricity!
I wired up a LED light bulb to turn on via motion sensor for the bathroom light that the box is connected to. When the cat comes in the room to do their business, the light automatically turns on for them. The fan on the other hand turns on and off with specific intervals throughout the day to help reduce electricity. Full disclosure....my cruddy computer fan kicked the bucket early on, so I ended up replacing it with an off the shelf desk fan. No problems since then.
Step 9: Tunnel, Door, and Conclusion
I created a wooden tunnel to connect the bathroom to the garage using plywood. I cut a hole in the wall and secured my tunnel in the wall. I covered the bathroom side with a door and trim. The tunnel got sealed and painted. It took a week or so for the cats to figure it out, but they haven't had a problem since. I hope you have enjoyed this instructable. Leave any comments or ideas you might have. Cheers. Get in touch with me at http://www.curtosnoir.com
Hiding Places Contest
Second Prize in the
    • Casting Contest
      Casting Contest
    • Flowers Challenge
      Flowers Challenge
    • Woodworking Contest
      Woodworking Contest
    11 Comments
    this is awesome! I bet you could put a motion sensing light switch directly inside the box that powered both the light and the fan when a cat came in.. no manually turning it off and on or setting your timer.
    Nice job. My father and I created a couple of these nearly 30 years ago. Works like a charm. He even put his on his balcony of his rented apartment. He made the hole through the drywall behind the living room curtains then just patched it up when he moved
    I bet this was when considering having a cat as a pet. :D
    I was not a big fan of cats when I met my wife, so she assured me that I wouldn't ever have to scoop the litter. lol (Truth is that I have had to scoop it on occasion but such is life)
    This is a much better project than anything I've seen. Yes, it's not that pretty, as a hidden drawer or something like that, but it sure is more effective.
    I am all about functionality!! I was only concerned about making it attractive looking from the bathroom side of things.
    it's good but why do you say you don't need to take the poop out?
    This is brilliant! I'm the cat person of the house, so my wife is always complaining about the "stinky cat box", regardless of how often I change it. This should solve the problem. Thanks a lot!
    Thank you so much! I built it to be removable (minus the hole in the wall) so that we can take it with us to the next house. My wife loves it because she can skip a poop scoop because of the added litter box and the vent. Good luck to your build, feel free to message me if you have any questions. :-)
    Excellent!
    I have to say, I love style of all of your cover photos. Very nice work, all around!
    Thank you very much! I actually just got finished updating all of them, so good eye!
