Introduction: How to Hook Up a Trailer.
Picture of How to Hook Up a Trailer.
Step 1: What You Need
Picture of What You Need
You need the right size ball and hitch to match the trailer and weight requirements, a truck that has a hitch with the right towing capacity for your purpose, a trailer that is certified and insured.
Step 2:
Insert the ball hitch into the truck hitch and fasten with a pin and safety clip.
Step 3: ​Prepare Trailer So You Can Connect the Ball.
Picture of ​Prepare Trailer So You Can Connect the Ball.
Open coupler lock, and make sure the trailer is raised at the right height so the ball can fit underneath.
Step 4:
Picture of
Back up the truck and position the ball directly underneath the tongue and lower the jack that the weight of the trailer is fully on the ball.
Step 5:
Picture of
Close the coupler lock and be sure it is fully locked then insert safety pin into the lock.
Step 6:
Picture of
Raise the jack to full height and hook up the chains and electrical cord.
Step 7:
Picture of
Make sure all lights and signals are functioning including brakes (if equipped).
Step 8:
Picture of
Your all set to go haul.
Step 9:
DesertRick (author)2017-02-23
Good Instructible. You've got the basics covered. A couple of things. One would be to NEVER EVER use any type of locking device for the safety pin (step 5). In case something on the trailer starts to burn (or vice-versa), you want to be able to disconnect quickly and not be searching for a key. Other is to cross the safety chains/cables (step 6). Theory is that if the trailer somehow becomes unhooked, the trailer hitch will drop into the crossed chains/cables and be cradled by them, instead of just dropping straight into the ground and digging in.
tomatoskins (author)2017-02-23
Great instructions! Thanks for sharing how you hook up your trailer!
About This Instructable
173views
3favorites
License:
More by Fendt1050:How to hook up a trailer.
Add instructable to:
