3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Install Flash on Ubuntu Linux, the easy way!
One of the the few things I don't like about Linux is how hard it can be to install new applications, or plugins, this can be hard if you aren't very good using Command lines and prefer using a GUI - pronounced Gooey (graphical user interface)
this instructable covers using 7.10 (gutsy gibbon) it should work with most Ubuntu distros though.
Step 1Getting the required stuff
before doing this please follow This instructable, otherwise this will not work you can find it
ok first you need to go to http://www.adobe.com then click the "get flash" icon on the right hand side of the page. It should automatically detect the fact that you are using Linux and give you the correct file types.
click download, and save to disk the tar.gz file you DON'T want the .rpm or YUM files.
8 comments
Mar 31, 2008. 10:03 AMadmin says:
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
Apr 21, 2009. 9:48 AMN1CK4ND0 says:
Omg finally, I have still yet to set up flash on my Ubuntu server, then again, I don't really need it... But good 'ible anyway!
Oct 28, 2008. 1:45 PMwazupwiop says:
umm.... why can't you just get a flash plug-in for firefox? Instead of having to do it this way
Jun 10, 2008. 11:21 PMmagnus0 says:
Actually it's easier from the terminal. just type: sudo apt-get install flashplugin-nonfree and you're done
Jun 11, 2008. 1:12 PMmagnus0 says:
It has always worked for me. Basically it's the same thing, it downloads the same plugin from the adobe site, and does the installing for you.
Apr 27, 2008. 8:21 AMLevLiveDotCom says:
Actually, if you have problems with command line management, then it may be easier to in fact download the rpms. While rpms are designed for Redhat systems, they usually can be converted to be fully functional Debian packages. All you need is a program called "alien". On Ubuntu: sudo apt-get install alien
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:F1X0R
