How to Install HIDs [Headlight Conversion Kit] DIY on 2012 Ram Quad Headlight Trucks
118
Posted in TechnologyLeds
Introduction: How to Install HIDs [Headlight Conversion Kit] DIY on 2012 Ram Quad Headlight Trucks
Hello everyone! I finally "ve got another" car hid headlight DIY tutorial for you guys, this time it's and HID conversion kit on how to Install BFxenon HIDs on 2012 Ram Quad Headlight trucks. It's REALLY EASY =] I hope you all enjoy!
Step 1: ​Remove Grill to Access the Headlight Bolts. You Will Need a Flat Head Screw Driver to Remove the Clips and a 10mm Socket
Step 2: Pull the Grill Back, Lift Up on the Large Tab and Pull the Grill Back at the Same Time.
Step 3: Remove the 2x 10mm Bolts That Hold the Housing in Place.
Step 4: Pull the Sliding Clip Down and Remover the Bolt. in the Fender Well Is a Access Panel to 1 More 10mm Bolt and a Long White Plastic Sliding Clip That Holds the Headlight In.
Step 5: Once You Have the Headlight Housing Out, You Will Need to Remove the Cap and Drill a 1″ Hold for the Wires to Come Through.
Step 6: Remove the Factory Bulb and Replace It With the BFxenon HID Bulb.
Use the 2 exposed leads to plug into the factory plug (for power to the ballast).
Black to Black and Red to White and Blue
Step 7: Replace Cap Back Into Factory Housing With the HID Wires Coming Out the Back. the Wires Coming Out of the Factory Plug Go Into the Anti-Flicker Kit and the Anti-Flicker Kit Goes Into the Ballast.
Step 8: Mount the Ballast and AF Kit. These Are Recommended Mounting Points… You May Mount Them According to Your Preference.
Step 9: Test Lights Before You Re-install All the Parts.
This ensures all the wires are connected properly and you have mounted the ballasts away from any interferences
Step 10: Secure All the Bolts Back Ion Place and Re-install the Grill
Visit Our Website for More Informaiton @
www.BFXENON.com
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Thank You Guys...
