How to Install ROS Kinetic on Raspberry Pi 3
2,693
4
Posted
Introduction: How to Install ROS Kinetic on Raspberry Pi 3
The OS version used by me on Raspberry Pi 3 is Ubuntu MATE 16.04.2.
The ROS version that I have installed is Kinetic Kame. Kinetic was released early last year and is compatible with Ubuntu Mate 16.04. I chose this version for two reasons:
  1. it will be officially supported for the next five years;
  2. it is the most complete version after Indigo;
The first step in installing ROS on Raspberry Pi 3 is called Mate. Ubuntu Mate. The operating system is simple to install. I followed the steps on the download page, and within minutes I managed to have a Pi 3 running Ubuntu Mate.
What you find below are the steps to install ROS Kinetic on the Raspberry Pi 3.
Step 1: Go to System -> Administration -> Software & Updates;
Step 2: Check the checkboxes to repositories to allow “restricted,” “universe,” and “multiverse.”
Step 3: Setup your sources.list
sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
Step 4: Setup your keys
wget http://packages.ros.org/ros.key -O - | sudo apt-key add -
Step 5: To be sure that your Ubuntu Mate package index is up to date, type the following command
sudo apt-get update
Step 6: Install ros-kinetic-desktop-full
sudo apt-get install ros-kinetic-desktop-full
Step 7: Initialize rosdep
sudo rosdep init
rosdep update
Step 8: Setting up the ROS environment variables
echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc
source ~/.bashrc
Step 9: Create and initialize the catkin workspace
mkdir -p ~/catkin_workspace/src
cd catkin_workspace/src
catkin_init_workspace
cd ~/catkin_workspace/
catkin_make
Step 10: Add the catkin_workspace to your ROS environment
source ~/catkin_workspace/devel/setup.bash
echo “source ~/catkin_workspace/devel/setup.bash” >> ~/.bashrc
Step 11: Check the ROS environment variables
export | grep ROS
Step 1: Check the ROS Installation
  1. Open a new terminal and type: roscore
  2. Open a new terminal and type: rosrun turtlesim turtlesim_node
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
