How to Install Vinyl Decal Using Hinge Method
111
Posted
Introduction: How to Install Vinyl Decal Using Hinge Method
This method works great for when placement and accuracy is important.
Step 1: Tape in Place
Tape graphic in place. Make sure its level and where you want it because if done right it will stay exactly where you taped it.
Step 2: Peel
Peel backing paper away from transfer tape. Only peel up until where you taped the graphic.
Step 3: Cut
Cut backing paper in half. DO NOT cut transfer tape or decal
Step 4: Apply
Now pull graphic tight and from the center outward apply even pressure across graphic using a credit card or any flat edge.
Step 5: Apply Other Half
Remove the tape that you used to secure graphic. Start peeling backing paper off from center outward. Apply pressure with flat edge from center outward.
Step 6: Peel Away Transfer Tape
Now peel away transfer tape SLOWLY. Peel along the surface and not by pulling towards yourself.
Finally your done!
Step 7: Find More Info at Www.mndcd.com
vinyl decal customization & sales at www.mndcd.com
Facebook & Instagram @duluth_custom_design
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    2 Comments
    Once you get this method, you'll never mis-apply a decal again. The secret is never to peel away from the surface toward yourself - always peel sideways, along the same plane as the surface, while you smooth down the decal behind the peel with a credit card etc..
    That looks good, where we lived before there was a black car with yellow bat symbols on the sides that was really fun. :)
