How to Install Windows 10 in a Raspberry Pi
8,576
38
14
Posted
Introduction: How to Install Windows 10 in a Raspberry Pi
Hi,
in this instructable i will show you how to install windows 10 on raspberry pi ( no, i am not joking ).
Step 1: Get the Board and Tools Ready
The things required are-
1.A PC running Windows 10
2.Raspberry Pi 5v Micro USB power supply with at least 1.0A current. If you plan on using several power-hungry USB peripherals, use a higher current power supply instead (>2.0A).
3.8GB Micro SD card - class 10 or better.
4.HDMI cable and monitorEthernet
5.CableMicroSD card reader - due to an issue with most internal micro SD card readers, we suggest an external USB micro SD card reader
Step 2: Install the Windows 10 IoT Core Tools
1.Download a Windows 10 IoT Core image from our downloads page. Save the ISO to a local folder.
2.Double click on the ISO (Iot Core RPi.iso). It will automatically mount itself as a virtual drive so you can access the contents.
3.Install Windows_10_IoT_Core_RPi2.msi. When installation is complete, flash.ffu will be located at C:\Program Files (x86)\Microsoft IoT\FFU\RaspberryPi2.
4.Eject the Virtual CD when installation is complete - this can be done by navigating to the top folder of File Explorer, right clicking on the virtual drive, and selecting "Eject".
Step 3: Put the Windows 10 IoT Core Image on Your SD Card
1.Insert a Micro SD Card into your SD card reader.
2.Use IoTCoreImageHelper.exe to flash the SD card. Search for "WindowsIoT" from start menu and select the shortcut "WindowsIoTImageHelper".
3.The tool will enumerate devices as shown. Select the SD card you want to flash, and then provide the location of the ffu to flash the image.
NOTE: IoTCoreImageHelper.exe is the recommended tool to flash the SD card.
4.Safely remove your USB SD card reader by clicking on "Safely Remove Hardware" in your task tray, or by finding the USB device in File Explorer, right clicking, and choosing "Eject". Failing to do this can cause corruption of the image.
Step 4: Hook Up Your Board
1.Insert the micro SD card you prepared into your Raspberry Pi 2 (the slot is indicated by arrow #1 in the image below).
2.Connect a network cable from your local network to the Ethernet port on the board.
3.Make sure your development PC is on the same network.
4.Connect an HDMI monitor to the HDMI port on the board.
5.Connect the power supply to the micro USB port on the board.
Step 5: Boot Windows 10 IoT Core
1.Windows 10 IoT Core will boot automatically after connecting the power supply. This process will take a few minutes. After seeing the Windows logo, your screen may go black for about a minute - don't worry, this is normal for boot up. You may also see a screen prompting you to choose a language for your Windows 10 IoT Core device - either connect a mouse and choose your option, or wait about a 1-2 minutes for the screen to disappear.
2.Once the device has booted, the DefaultApp will launch and display the IP address of your RPi2.
Step 6: Connecting to Your Device
1.You can use Windows Device Portal to connect to your device through your favorite web browser. The device portal provides configuration and device management capabilities, in addition to advanced diagnostic tools to help you troubleshoot and view the real time performance of your Windows IoT Device.
NOTE: It is highly recommended that you update the default password for the Administrator account.
Step 7: Finish Off
Now you should be ready with a windows 10 raspberry pi. If you have any doubt just ask in the comments.
(Please vote too )
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    9 Comments
    i want to run windows 10 full version on raspberry pi not windows IoT.
    is there any way?
    Nice instructable. Gets my vote IF you fix a dangerous error in the first step. The power supply should be 5V not 25v.
    Guys need windows 10 key that i suggest you go site www.zescode.com to got. 100% genuine it to provide.
    This isn't really the place for advertising. Also, that's for full computers, not the Raspberry Pi. The prices on the site are also high; Windows 10 Home is only about $15 for an OEM key.
    Good info, thanks for sharing!
