How to Install a LTC1799 Precision Oscillator in a Korg EM-1 Electribe
4,275
4
5
Posted in TechnologyElectronics
Introduction: How to Install a LTC1799 Precision Oscillator in a Korg EM-1 Electribe
hi !
in this instructables i'll show you how to instal a GetLofi LTC1799 precision oscillator kit ;
First sorry for my english, its not my language so i do what i can :))
I bought a kit from us one year later for my Korg EM-1 , i was searching on how to install it , but theres nothing on the net about it , except a video showing you how it works once you already install it; The video was made by GetLofi, and i thought that they wil answer me if i asked them how to install it....but after trying to send them a couples of mails with no answers , i decided to do it myself;
the reason i wanted somebody to explain me how to install it is that the Korg EM-1 is full of different chips, and some make undesirables sparkles when you touch their pins....i didnt want to act as a circuit bender on a machine that i can sold 150 euros , by testing connectors everywhere and finally (maybe) found something; But actually thats what i did, and i also found interresting bends in the korg Em-1 (that i will show you in a next instructables :) )
For people who are wondering how the precision oscillator works , it affect the pitch on devices, such as grooveboxes, gameboy, synths and drum machines, cleary it overclock or underclock the device :)
Tools :
-A Korg EM-1
-A ltc1799 precision oscillator kit (or even just the pcb)
-soldering iron, copper wire, tape , screwdriver to open yr electribe
-Patience :)
Step 1: Open the Korg EM-1
i didn't got pics of this part , but you will see its pretty easy , as the screws on the back plate are the same than the ones on the PCB ;
the korg is divided in two PCB , the one which interest us is the first one you will found when you put off the back plate. go gently , especially when you take off this pcb : the potentiometers are quite long and are really annoying when you put the pcb off; maybe the on/off button of the electribe will stuck it , just push it and you will get the circuit board;
Step 2: Checking the Solder Points: THE CLOCK
so here are the soldering points ; the precision oscillator from Getlofi got 5 connections : 5v , out, ground, and 2 for the potentiometer
You can found how to wire it here : http://www.getlofi.com/wp-content/uploads/2008/10/2_LTC_Instructions.jpg
to found the clock, just take a look at the big chip on the left side of the board; the point is the one i show you on the picture;
as you can see it would be pretty hard to solder something on this chip, the pins are really tiny !! So i figure on how to wire it , just look  the back of the pcb , and you will see a solder point (see the second  and third picture) no problem to wire this one !
Step 3: Checking the Solder Points: +5 Volts
theres a few +5v points on the circuit board , all aready wrote on the pcb, so no problem to found this ;)
its important to found a source of power who power off when the machine is off ; Korg EM-1 is off the voltage is off too on the +5v point i choose on the picture .
Step 4: Checking the Solder Points : the Ground
Theres thousand of ground points you can solder on the board, as you can see on the pictures ; i choose one on the upper back side of the pcb (the black wire) ; but you can choose others theres no problem
Step 5: Place the Pcb, Potentiometer and Switch
once you finish to wire the precision oscillator kit to the korg em-1 , solder the two wires to the potentiometer you could found inside the kit (if you dont bought the kit but just the pcb, a 500k pot will be fine); you will have to hook up a switch to the "out" wire of the LTC1799 pcb, so like that you can switch on the electribe without make it freeze on the loading process; i choose to place the potentiometer and the switch on the faceplate of the korg EM-1;
after that, just put back the screws and ........done !!!! you can enjoy your precision oscillator !
for my part it just work well, i have to add some resistance to the wire because the system tends to glitch and freeze at very very low pitch , thats normal and on get lofi video description you can see that it glitch and freeze at 3k of resistance; the resistance supported depend on what kind of device you are using
hope you enjoy this instructables , if you got any questions just ask ;
Merry xmas and happy new year to all !
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Space Challenge
      Space Challenge
    5 Comments
    Hey, man! Thanks for linking to my video, I love it! But, there are a couple things....When I do the pitch mod-I always pull out the stock clock to avoid noise and crashing and install the LTC1799 module's output straight into the socket where the clock was. You can setup a switch with a resistor to replace the clock for boot. The other thing, I'd try to avoid soldering directly to the chip-it's easy for even an experienced CB/DIYer to leave a solder bridge.
    Nice to see other people doing this stuff!
    thanks a lot for all this informations !!! so what i need to do is unsolder the clock pin of the chip and solder the output of the kit directly where this pin was solder ? mean that i didnt use the stock clock anymore ? what kind of resistance should i have to add to the switch for preventing the unit to crash? sorry for all this questions but its important ;)
    Nice one! I don't have this rig, but would be curious to hear your modified unit and what you can do with it. Will you post a video?
    hi ! thanks stubbsonic ! actually i have not made any video yet, but to give an idea on how it works just take a look at this video : http://www.youtube.com/watch?v=zmH35puPTfg ....my unit do exactly the same job now :)
    Great hack! Well worth the time. I love those things that take a rig to the edge of crashing where interesting things happen.
