How to Install an E27 Lampholder
Published
Introduction: How to Install an E27 Lampholder
About: Maker, Hacker, Creator? All of the above? Driven in large part by the inspiration gained from other YouTube creators, I wanted to contribute my own projects and stories to this wonderful community. To share ...
In this instructable, I install an E27 Lampholder to a lamp and install all of the wiring.
Step 1: E27 Edison Screw Lamp Holder
This is an E27 lampholder, also known as an Edison screw. It works with traditional incandescent bulbs, CFL bulbs and newer LED bulbs.
E27 lampholders sometimes get stuck in a locked safety position and need to be unlocked before they can be installed.
Step 2: Unlocking the Lampholder
In order to unlock a Lampholder, locate the center terminal that goes to the edge of the bakelite socket.
Press down on the edge with a screwdriver. You may have to press a few times to get it to unlock
It is a matter of approximately 1 mm. You then twist the socket and unscrew it when the terminal has been pushed down sufficiently
Step 3: Connecting the Power Cable to the Socket Screws
With the socket taken apart, I strip the ends of the electric cable and screw it into the socket screws.
If you have a 3 wire cable with a ground wire, you would connect it to the screw located at the base of the socket.
Step 4: Threading the Wire Throught the Lamp's Chassis
I disconnected the lampholder and threaded the wire through the lamp chassis. I then screw the lampholder to the lamp base.
With the lampholder on the lamp base, I tie a relief knot in the electric wire which will keep the wire in place.
I then reconnect the wires to the socket screws
Step 5: Adding the Lamp Shade
I screw in the lampholder and lock it in the secure position. I then add the lampshade
Step 6: Connecting a Plug to the Cable
With the lampholder installed, I then proceed to attach an electric plug to the other end of the cable and an on off switch
Step 7: Connecting an on / Off Switch
Step 8: Testing the Working Lamp
With everything connected, I test to make sure that everything works as it should.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
