3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Install the Arduino to the Lithium Backpack
The Arduino is an open source hardware input and output circuit and the Lithium Backpack is a Ardino accessory that will power the Arduino when it is away from a computer or a wall power. These products are sold at Liquidware for under $34 each.
Step 1Plug in the battery connector to the board.
The black wire should face the outside (away from the battery).
19 comments
Sep 26, 2009. 9:03 PMTXTCLA55 says:
You know you could have just used a 2.1mm jack and stripped the ends of it, determine positive and negative (negative normally is white) and plugged it into the external Ardunio power plug. That way you can use the ground and +5 headers for other stuff like servos or sensors. Anyways just a suggestion.
Mar 10, 2012. 11:23 AMgehrc says:
How would this work for the 3.3v pin then? Same thing, just use the 3.3v connector on the battery pack?
Mar 10, 2012. 11:22 AMgehrc says:
I'm guessing you can't use both 5v and 3.3v pins since it only outputs 4.2v? In this case, you just plug it into the 3.3v pin then from the 3.3v connector on the battery? Does this make it last longer?
Aug 4, 2011. 10:14 AMalien200049655 says:
Whats the voltage and amperage on the Li-Po battery, Is it rechargable?
May 17, 2011. 7:06 PMThe nerdling says:
why is you arduino all steampunkish?
Jun 4, 2011. 7:43 PMJimmacle says:
What do you mean by steampunkish? Looks normal to me.
Jun 4, 2011. 9:20 PMThe nerdling says:
in the pic your arduino is goldish so it looks like its steampunked
Aug 4, 2011. 10:17 AMalien200049655 says:
It's probably a result of the cameras picture quanlity, and lighting conditions at the time. But its creates a very nice antique picture look.
Jun 27, 2009. 1:43 AMinthebitz says:
i just made another instructable for the same thing, except with using the arduino mega and the mega backpack over here: http://www.instructables.com/id/Powering-the-Arduino-Mega-with-a-Lithium-Battery/
Jun 8, 2008. 6:42 PMlordofthedonuts says:
It's a great product but at a price higher than the Arduino itself, I don't know if it's worth it.
Jun 25, 2009. 2:26 PMReCreate says:
Well...I found One for about 2 Dollars Less...http://www.sparkfun.com/commerce/product_info.php?products_id=666
Its 29 Dollars there...So...Yeah...
Dec 29, 2008. 6:42 AMcomputer_freak_8 says:
I have a question. You wrote "Power Switch: The Lithium Backpack will charge when the switch is in the left position (Chrg). The Backpack will output 5V and 3.3V when the switch is in the left position (Batt)." So... which one should say "the right position"? (They both say "the left position".) This is on the second picture on the "intro" step.
Dec 30, 2008. 9:41 AMcomputer_freak_8 says:
Okay, thanks!
Jun 8, 2008. 11:49 AMNotbob says:
Looks good, but what is an Ardino?
Jun 8, 2008. 11:50 AMNotbob says:
*Arduino
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Severino
