3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to JTAG your Xbox 360 and run homebrew
Step 3Soldering the cable
Soldering the cable
Soldering is generally pretty straight forward.  You actually don't need any solder for the motherboard end, as the holes all have solder in them.  So you just need need to heat it up and slide the wire through.  I suggest using at least a 30w iron as a 15w will have trouble getting the lead free solder hot enough.  All resistors on the connector are optional, it's just to prevent damage as some ports are 5v and the motherboard is 3.3v.
Here are some bigger pictures
Xenon
All others
Recently there has been a new way to wire Xenons that is supposed  to be better, I have never tried it but I have included the diagram on how to wire it.
New Xenon
10 comments
Aug 26, 2011. 12:17 PMocas890 says:
u should really dump the nand through nand-x instebd of lpt
Jul 20, 2011. 8:40 AMrdavis14 says:
Does anyone know where to buy an xbox 360 nalready jtagged with homebrew?
Aug 1, 2011. 1:47 AMdbarker4 says:
i got 2 for sale in australia!
look me up in facey.. username xboxsc
Jul 28, 2011. 1:40 PMsudburymods says:
http://www.sudburymods.com
Apr 3, 2011. 3:53 PManilsson1 says:
Don't use this outdated method if you have a Zephyr, Falcon, Opus or a Jasper. I used this and had to re-do it all a few days later because I got red rings, which is common with this method. Here is the best method:
http://forums.xbox-scene.com/index.php?showtopic=719652
You need, in total,
5x 100 ohm resistors (for LPT)
2x 10 000 ohm resistors
2x 2n3904 transistors
a db-25 male connector (for LPT)
1x 1n4148 diode (for LPT)
Mar 11, 2011. 3:59 PMmachine156 says:
is it just me, or is EVERY picture I have found of the JTAG pin out BACKWARDS from the pins in reality...
acording from my link below and my LPT port, when looking from the FRONT pin 1 is on the top right...
ever JTAG picture i've seen, including the one above, pin 1 is on the top right when looking from the BACK... why is this? I'm wondering if that's why it is failing for me...
http://www.doc.ic.ac.uk/~ih/doc/par/pinout.gif
Mar 13, 2011. 11:05 AMBroo says:
If you are looking at the male end (where the pins extend out) of a DB25 male connector, pin 1 is in the upper left (UL). if you are looking at the rear (solder side) of a DB25 male connector, pin 1 is in the upper right (UR).
Most pin-outs show the rear pin-out as that is the side where the wires need to be soldered (so pin 1 is UR). The front will be the mirror image of the rear.
Here is another JTAG with some pics of the actual connector:
http://mod360s.com/jtag.html?start=1
Also- most D-shell connectors should have (very tiny) pin numbers printed (at least for pin #s 1, 13, 14 and 25) on the backplate that holds the pins.
Mar 14, 2011. 4:49 PMmachine156 says:
yes, cool, it is backwards in all Xenon motherboard pictures... My LPT port has numbers and a red stripe on Pin 1, but i just looked at the picture, witch through me off...
I've got it to flash, but it wont boot, i can flash the original nand back to the xbox and it boots, i've tried flashing the modified one several times like suggested and it still wont boot...
Jun 28, 2010. 2:34 PMminutemadeinc says:
What gauge wire are you using?
Sep 26, 2010. 2:39 PMap16 says:
22 worked perfectly for me
Jul 24, 2010. 11:17 AMhackgamer37 says:
im using 28 gauge i think he is too
May 18, 2010. 12:42 AMo iL3GeNDz v1 says:
:O what the heck r u talkin bout i cant understand it :@ comment on a simpler way to put it
Apr 15, 2010. 12:33 PMErictronik says:
Thank's buddy, very professionnal Instructable and hey you got the job done! Very neat Tuto!!! :o)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:CowGuy
