3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to JTAG your Xbox 360 and run homebrew
Step 4Dumping the nand
Dumping the nand
Download the files here (I forgot to include nandpro get that here)
Extract the rar, and open up the nandpro folder
install port95nt.exe (if running vista or 7 set it for compatibility mode for xp.)
Plug your Xbox 360 in, but don't power it on.
Plug the lpt cable in
Pop open cmd and change directories to your nandpro folder
type nandpro lpt: -r16 nand.bin
It will start to dump, this will take 35 minutes
Type nandpro lpt: -r16 nand2.bin and dump it a second time.
If during the dump it has trouble reading blocks, don't worry.  You only have a problem if can't read block after block, which means something went wrong in the middle of the dump and you have to restart it again.
If you are having issues having nandpro detecting it, go over and double check all of your soldering. If you skipped out on the diode, try adding one, and just restarting your computer has fixed the issue quite a few times for me. You also want to make sure your cable is short as possible.
26 comments
Apr 9, 2012. 11:37 AMHay1tsme says:
does this work for 2.0.14719.0
Apr 11, 2012. 2:37 PMtfleming1 says:
No man sorry.
Apr 5, 2012. 4:06 AMHay1tsme says:
i can't install porn95nt.exe, it says incompatability with x64 bit verson of windows 7 (i did change the compatability to Windows xp service pack 2)
Dec 14, 2011. 3:45 PMstephin99 says:
This goes out to all having trouble dumping nand through lpt
1. make shure 360 is plugged in both wall and motherboard
2.make shure plugged up to lpt good and snug
no results then go into to system bios and check if lpt is
1. enabled
2. set to EPP+ECP mode or into normal if in EPP+ECP
still no results
1.check soldering
2.check soldering
3.check soldering
nothing again?
1.check direction of diodes
2.add/remove the 100 ohm resisters on pins 1,2,14,16,17
nothing again bad lpt port/xbox
Sep 19, 2011. 12:09 PM02kingdam says:
I had tried reading the nand and got the error about flash cannot be found i resoldered everything and then after around an hour... i then read that the power plug had to be inserted into the xbox 360 and it plugged into the wall after i done this it read first time on port 0378 so this is just a tip for those who also receives this error
May 9, 2011. 12:55 PMModscientist says:
getting an error trying to dump:
Testing LPT device address:0378
Testing LPT device address:0278
Testing LPT device address:03BC
Could not detect a flash controller!
Can not continue
help !!?????
Sep 19, 2011. 12:06 PM02kingdam says:
Like a previous statement ensure that your XBOX POWER PLUG is inserted into the xbox when using nandpro but DO NOT TURN XBOX ON!!
Jun 29, 2010. 6:02 PMbrandon-scott says:
I have checked my soldering very many times and added the diodes and restarted my computer but nandpro still doesnt detect it, What do i do?
Sep 19, 2011. 12:05 PM02kingdam says:
Jul 13, 2010. 3:26 PMben ehrlich says:
did you make sure the diodes are facing the correct direction, thats what my problem was, it took me hours to discover it, i was about to give up too.
May 9, 2011. 7:01 AMModscientist says:
how do i Pop open cmd and change directories to your nandpro folder?? help
May 17, 2011. 1:26 AMelizle says:
Use the cd command. As in "cd Nandpro20e" use "dir" to see what is in your directory. Say the nandpro folder was on your desktop, you would type "cd desktop" hit enter and then type "cd Nandpro20e" or whatever you named your nandpro folder. cd means Change Directory. Another thing you could do is just open up notepad and make containing "nandpro lpt: -r16 nand.bin" and save that as nand1.bat making sure you hit show all files before you save. To see a list of commands in command prompt you can type "help" and it will list some basic ones for you. I hoped this helped.
Dec 10, 2010. 7:21 PMboolean says:
Can not continue
May 9, 2011. 11:09 AMModscientist says:
hey i got the same error how did you fix it help ?
May 9, 2011. 9:31 AMModscientist says:
hey how do i change directories to my nandpro folder help ?
Mar 4, 2011. 10:58 PMsanddune600 says:
I got this to I reread the instructions and found that when it says plug in the 360 it means the power cord I thought it meant plug the lpt cable to the 360 then plug the lpt cable to the pc
Dec 10, 2010. 7:49 PMboolean says:
i even tried adding a diode to DB25.11 to J1D2.4, tried it both ways to get the polarity.
Dec 11, 2010. 12:18 PMboolean says:
J281 actually
Dec 11, 2010. 12:10 PMboolean says:
Thank you for the reply but I am still having trouble. I've narrowed down the problem maybe, because i noticed if I unplug J2D1.5(I think that's the part where you just use 5 and 6) the xbox will be able to start up while plugged into the computer.
Apr 11, 2011. 7:01 PMsteven9 says:
What if your running linux?
Dec 21, 2010. 2:59 PMryguy425425 says:
Wasn't detected at first, got the
Can not continue
error. I unsoldered everything, used a thicker guage wire (instead of the gamecube controller wire I was using), and got rid of the diode. I resoldered and triple checked everything, and it is now dumping.
I also used this wiring diagram: http://forums.xbox-scene.com/index.php?showtopic=693742
(the new xenon one).
Nov 25, 2010. 12:11 PMTimonator says:
I have made like 8 nand dumps of my Falcon MoBo. But when I open degraded 1.1 It gives another bad sector on each nand dump. Which one can I use?
Sep 25, 2010. 8:21 AMocas890 says:
what service pack for xp
Aug 29, 2010. 2:43 AMextasey says:
Where do you put the diodes?
Jun 2, 2010. 8:09 AMjstrumpfler says:
 on the nand pro its saying im missing the dlportio.dll fille what should i do?
Jul 13, 2010. 3:28 PMben ehrlich says:
i think that is port95nt.exe but I could be wrong, did you try reinstalling it?
Jul 11, 2010. 4:10 PMben ehrlich says:
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:CowGuy
