3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to JTAG your Xbox 360 and run homebrew
Step 9Installing a 3.5 in desktop HDD
This requires you to cut the end off a sata cable and solder it under the HDD connector.
Wiring goes as follows
Pin 1: SATA Signal GND
Pin 2: SATA Signal A+
Pin 3: SATA Signal A-
Pin 4: SATA Signal GND
Pin 5: SATA Signal B+
Pin 6: SATA Signal B-
Pin 7: SATA Signal GND
The side of the sate cable with the writing goes up, and you start left from right.  You only have to solder the white shielded cables inside as these are the data cables.  Just wire the rest of the ground wires some where else.
Where to get my 12v?
There are many spots on the Xbox motherboard where you can get 12v of power from, I picked the power connector on the bottom of the board as I'm not soldering onto any other connectors or anything.
How to wire up the sata power connector
Yellow: 12v
Red: 5v
Black: GND
Hard drives have been tested up to 2tb and worked successfully.
9 comments
Aug 2, 2010. 10:54 PMsupaaben says:
ok dude so i currently have a samsung dvd drive in my jtaged xbox but it doesnt work properly when i put a game is it says "play dvd" when i press A it goes to the xbox boot screen and jus freezes there. if i were to do this wilth a 300 gb drive what would it show up as in xexmenu?
Dec 8, 2010. 10:47 AMWally_Z says:
It wouldn't work because Xbox's only accept up to a 250GB HDD. Anything over that will not work. You can also make the HDD piggyback on the top of the Xbox. It may not look the best, but why not do it if you have the time and money.
Dec 8, 2010. 12:31 PMWally_Z says:
If you are running FreeBoot then yeah, you can go much higher. I am talking about the people who don't know how to boot to another OS or program. A stock Xbox of any variety, (Arcade, Pro, Elite), can only use up to 250GB HDD. You can use flash drives up to I think 32GB. If you get USB hubs and like 24 32GB flash drives, then you are quite set.
Nov 11, 2010. 2:08 PMangryknome94 says:
yo try replacing the sata cable that goes to your disc drive i know it sounds crazy but it has worked on both of my xboxes when it showes anything that you put in the disc drive as "play dvd"
Sep 21, 2010. 1:41 PMlewisjay1 says:
Yes it would
Apr 9, 2010. 9:09 AMsumdude4 says:
What if your dvd drive is fried "including the circuit board" and needed a new one? There a way to upgrade the DVD drive (like toshiba to a benQ) ?
Mar 1, 2010. 11:09 AMJayceetoo says:
 Is it necessary to install a HDD ?
Mar 8, 2010. 6:16 PMshea3498 says:
my cd drive broke so if i do this will i need a cd drive
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:CowGuy
