3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Jump Higher (increasing your vertical leap)
Step 3Practice Makes Perfect
There are several ways to go about jumping. These are all great methods of training your legs to jump properly and with the maximum amount of force. Try them all and you are destined hurdle any obstacle:
1. Explosive Jumping:
For this exercise, you will need some sort of elevated platform (a rock, a bench, a cinder block, etc). Put your right foot on the platform and your left foot on the ground. Now, explode upwards, jumping as high as you can off of your right foot. On the way down, try to switch your footing, landing with your left foot on the platform and your right on the ground. This can be tricky, so be careful not to fall as you land. Repeat as necessary.
2. Box Jumping:
You'll need a box or a sturdy platform for this next exercise. Begin atop your platform, and jump off to one side. Try to land and then instantly jump back up again, bending your legs as little as you can while still generating enough force to reach the height of the platform. Land on top, and jump off the other side. Keep repeating this about ten times before taking a short break.
3. Lunge Jumping:
Get in a normal lunge position, and try jumping as high as you can, using your forward foot to drive the leap. The lower you are to the ground, the more muscle strength is required to get yourself airborne. Do this a few times for each foot before throwing in the towel.
4. Two-Footer:
Place your feet about shoulder width apart, and squat down. Push off with both feet and use them equally to jump as high as you can. This is a good way of working both quads at the same time rather than doing them separately.
5. Arm Experimenting:
Try taking a few jumps as you would normally. Now try jumping as high as you can while keeping your arms pointed straight down. See the difference? Swinging your arms during a jump can add a significant amount of inertia to your leap, so experiment with different methods of propelling yourself with your arms.
6. Why Weight?
Weights can also be used when jump training. Try doing some of the exercises mentioned above while holding weights or a lead vest. For a cool experiment, grab a pair of dumbells and crouch down. Before you leap up, drop the weights and you will jump super high. Your body adjusts for the added weight as you crouch and this over-compensation allows you to get some serious air.
Just a couple of notes:
Don't use ankle weights (or just about any ankle strength/jump training device). These cause your body to operate in an unusual manner and can tear ligaments, effectively sending you to the DL or even ending your career.
Keep records of your vertical jump with the help of some friends. Having a detailed record of your progress will help you to understand what exercises are best for you when trying to improve your vertical and can also bring your attention to other unknown factors in your jumping.
1 comment
Jan 22, 2009. 9:14 AMironman7 says:
You got some good stuff here. I'll try it out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:drums787
