This is an instructable on how to kiss. Kissing can be a hard thing to do until you get comfortable doing it, and while nothing can fully prepare you for a kiss, this how-to will explain some of the basics of kissing a partner and explore some simple kissing do's and don't's.
Note: I am by no means a kissing expert. The information in this instructable is based upon experience and some simple research on the subject.
Let's get started with just a simple kiss.
Step 1: Pre Kiss
The lead up to the kiss can actually be the most difficult part of kissing. Figuring out whether your partner is ready to kiss you or not can be a challenge of its own.
If you see one or a combination of these indicators, there is a good chance that your partner is thinking about kissing you.
  • eyes become soft and heavy
  • eye contact is made and sustained
  • head turns slightly
  • lips are licked or bitten
  • your partner makes physical contact with you beyond what seems appropriate for normal conversation (e.g. he or she brushes your hand, touches you on the shoulder or leg, or fidgets with an accessory)
  • easy conversation comes to a stop, but eye contact is not broken
  • your partner smiles in conjunction with any of the above behaviors
To give your partner the cue that you wish to kiss him or her, you can try one or a combination of these things.
  • soften your gaze by relaxing the muscles around your eyes, somewhat like smiling but without engaging your mouth
  • smile often, though
  • make eye contact and allow it to linger for a few moments longer than you normally would
  • find ways to subtly (but respectfully) touch your partner
If you think you are picking up some of these signs, but are still unsure if the person wants to be kissed then there is nothing wrong with just simply asking your partner if a kiss would be all right. Granted it breaks the mood a bit, and sensing the magic is always nicer than asking if it's there, but better to be sure your partner is on board for the kiss otherwise you might be heading for an embarrassing situation.
If you've assessed the situation, and it seems probable that a kiss is imminent, the next things to think about are timing and approach. The key to nailing the pre kiss is matching your partner's speed and intensity. The kiss is the first opportunity to physically connect with your partner, and so you want to meet him or her halfway.
Here are some steps you could follow as you go in for the kiss. Keep in mind that the kiss you share with someone is as unique as your relationship with that person, so follow your instincts and use the following as a rough guideline.
1. Establish a physical connection by placing your hands on your partner's body. Placement depends on the dynamic between you, you can softly touch the face, the back of the neck or the shoulders. Be gentle with your touch if this is the first contact you are making. Stay away from "high risk" zones on your partners body, as you just want to indicate that you are interested in kissing them, not give them a full body search.
2. Establish and maintain eye contact from this point on. The eyes are often a clear indicator if someone wants to be kissed, or is thinking about kissing you. Try to look at your partner with a deep, yet soft gaze. Use your eyes to send them a message that shows how you feel for your partner, e.g., "I care for you, I am on fire when I look at you, I want to kiss you."
3. As you lean in, you may want to tilt your body and head to accommodate your partner's positioning. One partner will have to make room for the other, or both partners can just slightly tilt heads in opposite directions. Basically you are just trying to avoid a nose collision as you get closer, so just pick a side to turn to and don't give it too much thought.
4. Gauge how quickly your partner is leaning in and try to meet at the halfway point between you, so neither person is overextended. Over/under extension can make one person feel like they are not getting met and are either too aggressive, or not engaged enough.
If you have come this far with your partner chances are you are going to kiss, or you have misread the entire situation and they are just leaning in to look at something stuck in your teeth.
If the first is true, then read on because it's time to pucker up and get on with THE KISS.
Step 2: Practice the Kiss
Once you're leaning in, things start to happen quickly. If you are nervous about the actual kiss, why not practice beforehand to hone your technique? An arm or mirror could serve as useful tools to self monitor the feel and look of your kissing style.
Rest assured, THE KISS is coming, but here it is broken down first, step by step so that you know whats going on when you see it at full speed with a partner in the next step.
Here is a head on view of a kiss. I am just practicing here, so it might look a little funny, but once your partner is sitting across from you and your lips meet theirs, it's H, O, T hot.
Check out the pictures below for the step by step break down of the video.
1. You are in the pre kiss state described in step 1 - your head is tilted, there is lip activity, your eyes are in a soft deep gaze and maybe there is some light physical contact.
You could open or close your eyes, though if you're nervous, closed could help avoid the deer in headlights look of fear. I like to start with mine open and close them just before lip contact.
2. Either you or your partner has shown that they would like to kiss. Start putting the pieces from step 1 together. Lean in and meet your partner halfway. Begin to pucker the lips by bringing them together, pushing them out, and applying just a faint hint of suction on your closed mouth to bring the cheeks slightly in.
Now is a good time to lick your lips if they aren't already moist.
Keep leaning in, remembering to tilt your head until you make contact with your partner's lips.
Remember not to forget about hand placement! A gentle touch to the back of the neck, the shoulders or your partners head is all you need. This can also help in guiding someone into the kiss if they are lost or are having trouble meeting you.
3. Your lips come to a full pucker position. They are soft, but not floppy. They can be fully formed and firm, but certainly not hard. This is an ambiguous state for any solid to be in - but these are your lips were talking about here - they can handle it!
Make contact with your partners lips.
If this is your first kiss, you don't want to linger too long, but you also don't want to just peck them and retreat.
Count "one-one thousand, two-one thousand" in your head before relaxing the pucker in your lips and beginning to pull your head away. You can hold the kiss like this for longer, but after 5 seconds or so should start think about ending this kiss. If you would like to keep kissing after that you can always lean in again and follow up the first kiss with a second, third or fourth kiss.
Remember to breathe through the kiss. It's all right to hold your breath for a short kiss, but for longer ones you are going to have to breathe while you are kissing. Since your mouth is occupied, you are going to have to use your nose. Just breathe normally and continue on with the kiss.
To end the kiss begin to lighten the pressure your lips are applying to your partners' and relax your puckered lips. As your lips relax they will separate and a small amount of air will be sucked into your mouth. This will create the kissing noise, or "smack" that is identified with a kiss.
At this point contact with your partner's lips has ended and its time to start thinking about giving them a little space and time to reflect about what just happened.
4. Move your head back slowly and begin to relax the muscles around your mouth. You can keep your eyes closed for a bit as you revel in the kiss and slowly return to your normal un-extended position.
5. You are now in the post kiss phase and if it was a good kiss, words won't do the feeling justice. If you and your partner liked what just happened you can follow up with more, or just enjoy what the two of you shared. If it was a bad kiss, you can try to make changes and give the kiss another go. If things can't be salvaged at that particular moment, don't force it - take a break and talk about it with your partner and try again after a few minutes or another day.
Step 3: The Kiss
Ok, it's time for THE KISS. Take all the elements from steps 1 and 2 and put them together. It's good to be methodical while practicing to kiss, but when it's time to do the real thing it should flow smoothly and come naturally. That means less step-by-step instructions, and more videos of the real thing.
Just a simple kiss.
Put a few of them together.
You can also touch your tongue to your partners lips ever so slightly. (This is not a French Kiss - just one method of placing the tongue towards the front of your mouth so you can just lightly brush your partner's lips upon contact.)
Step 4: Post Kiss
The post kiss is a lot like the pre kiss state, but more warm and gooey.
If you enjoyed the kiss show your partner that you liked it by smiling and/or holding their hand.
If you are going to kiss again keep things energized by maintaining physical contact with your partner even though you have pulled your lips away. For multiple kisses its ok to do the same thing over and over, but it's better to change things up a little bit. Here are some variables to think about modifying:
  • angle of approach
  • speed of kiss
  • length of kiss
  • kiss firmness/intensity
  • lip positioning (The first kiss is often a dead on approach, but offsetting one set of lips either up, or down can lead to a nice interlocking kiss where one partner's lips are nestled within the "lip valley" of the other partner's lips.)
  • hand placement
  • body placement
If you are done kissing for a little while just stare into your partners eyes and enjoy what the two of you just shared. Hopefully it will be the first of many and the twinkle in your eye as well as the smile on your face should make you feel like you are on top of the world.
Step 5: How NOT to Kiss
Kissing "don'ts" are just as important as kissing "do's". Just as doing all the right things can make for a magical kiss, doing all the wrong things could seriously throw a monkey wrench into your kissing future.
So remember, don't:
  • try to suck the face off of your partner. Kissing is exciting, and there can certainly be an urge to latch on and suck, but try to resist, as it will probably upset your partner.
  • force your tongue onto the scene. The right time to use your tongue while kissing will present itself after a few kisses, a few minutes or a few days. Forcing it too early or being aggressive with your tongue before you or your partner is ready is not a good idea.
  • kiss your partner with a mouth full of saliva. Remember to swallow excess spit before locking lips with your partner. While this is more of a problem with French kissing, if the saliva were to somehow find its way out of your mouth during a regular kiss, it could be problematic.
  • kiss with bad breath or fuzzy teeth. Practice good oral hygiene before kissing and take a second to think about whether or not your lips and mouth are a nice environment to kiss. It's true that kissing someone who has eaten onions or garlic can be pungent - so watch out for kisses after meals, but often if both partners have had the same thing to eat neither of them will mind very much.
  • miss your partner's face or misalign and hit noses. It's not the end of the world if this happens, but a simple turn of the head or glance to make sure you are properly aligned can help you avoid this potentially embarrassing situation.
  • don't run into trouble with braces. Locking braces, cutting your partner, or just clashing metal is a real danger when you or your partner have braces. Kiss gently when you have braces and take special care not to link your braces onto theirs. Kissing with braces is most definitely possible and having them shouldn't keep you from being a great kisser.
Even if you do make some of these mistakes none of them are unrepairable. Remember, kissing certainly is a big part of becoming close with someone, but it is by no means everything. If you do happen to have a bad experience just take a second to compose yourself, and try giving it another shot.
1-40 of 1674Next »
Animerocker says: Apr 30, 2013. 2:59 PM
Well I'm 13 and dating
Animerocker in reply to AnimerockerApr 30, 2013. 3:00 PM
Well people enjoy yall love life as yall can cause life is short so enjoy!
Vanseith says: Feb 25, 2013. 12:55 PM
This weirdo of a bf is a stalker you know that, but if I tell her she will not believe me. Any gut would have been better than him, but I don't know what she was thinking. Many times I wish that I was him, holding her in my arms, cuddling. They kiss too. I am so freakin tired of him luring her into kissing him like a teddy bear. Also, that guy picks on me even though I am way stronger than him and I am a red belt in taekwondo. If that guy messes with me he will get more than a stern talking to. If you're reading this please read my bottom comment too! Please help me before I get to angry at him for picking me and can't do anything about it because she will get mad at me for breaking his nose even though it didn't happen yet. One of these days I will get him but not any day close. Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Vanseith says: Feb 25, 2013. 12:46 PM
I have a crush with a girl in the same grade as me ( grade eight). I really really like her, but she has a bad boy boyfriend that gets in trouble all the time. I am just shy, but I am smart and I know that one day her bf will go to jail. Even though she has a bf, she is so beautiful and smart and can't risk my dignity to ask her out. I was her friend in grade 7 and we talked a lot but now she has that delinquent bf in her arms, I couldn't wish to think that if she did want him, she would have done that a long time ago. By the way her bf is one grade ahead of her. I skipped a grade because I passed a test, but this guy comes around in a stupid gas bike showing off to her that "he" is the one. I want to do something about it but I might end up losing our friendship. Please reply and help me in my relationship before it is too late!!!!!!!!!!!!!!!!!
san19777 says: Jan 15, 2013. 9:12 AM
can somebody please help me I'm 15 and i never kissed before or even had a girlfriend .But all my friends have smart, beautiful girls ALL OF THEM I am a little bit jelaous
Master97865 in reply to san19777Feb 18, 2013. 7:49 PM
Awe that's cute. Lemme tell you what. I'm three years younger than you and have a boyfriend. But we never talk in person, and we're really shy to each other. A lot of my friends have boyfriends and are always affectionate and stuff... But I came to realize that I don't get to hang with my bf very much because I don't go up and TALK to him. You go talk to girls and maybe you'll end up liking a special one and she might accept a date. Good luck.
christmas10 says: Jan 14, 2013. 5:30 PM
children go on this site
Inconsolable says: Jan 3, 2013. 10:51 PM
I will be honest. To all you kids who are 12-13-14 and are in 6th, 7th, and 8th grade, you are WAY too young to be in a serious relationship and to be trying to kiss someone so young and early. You need to get into a relationship with someone you have gotten to know for a while, became really good friends, have stuff in common, share the same interests, etc. But really, if you do all that and meet a guy/girl you like, don't automatically ask them out. Be friends for a while, and especially when you're older. Just wait until you're older. Trust me, you guys/girls who are about 12,13,14 etc, you don't know how to deal with a serious relationship yet. You may have to sacrifice a lot but if you really love them you will wait. Don't rush to get kissed, me and my boyfriend have been dating for 4 years, still going on strong, I'm in my senior year of High School. and I didn't ever kiss him until about 10 months into the relationship. We're planning on getting engaged right after High School. It's because, he was my childhood best friend, we'd always play together and have each other around. We have similar interests and so many things in common. And I love him so much. Anyways, back to what I was saying. It's not a contest to see who's a great kisser, who's cute, who's not, etc. It's about finding someone you love to be around and enjoy having. I hope my advice helped you! c:
clo11900 says: Dec 16, 2012. 12:48 PM
hay im in 7th grade and i've just broke up with my 7th bf... but honest to god in hindsight none of them really meant anything... but i've had some spark with guys that weren't exactly a "boyfriend" i have had a french kiss with a guy that i thought i liked and that i asked to kiss me but i by no means am a popular...but i dont know how to say ni can help but what other questions do u have?...
SamSamBunnyCat says: Dec 13, 2011. 7:07 PM
Dear Kids in 5th, 6th, and 7th grade,
How do you guys even have boyfriends and girlfriends? I'm in 8th grade and I've been single forever. I have no problem with being single...
jalawashere in reply to SamSamBunnyCatMay 14, 2012. 1:08 PM
well it is better when u r older so if u breakup u can accept it also i personally think dating and stuff should start at 6th grade
by the way there is someone in my grade that started dating in 3rd grade
Thundermoon99 in reply to jalawashereOct 17, 2012. 6:27 PM
i started dating younger then that lol but I'm in a committed relationship right now we've been together for almost 2 years now :)
january632572 in reply to jalawashereOct 15, 2012. 3:51 PM
Dating means you actually like the person and are doing sexual things with them. So Dating doesn't start until any of that happens. So 6th grade is a no. I was pregnant in 7th grade so all of you just need to stop with thinking dating is the cool thing to do. Dating starts in high school.
Master97865 in reply to january632572Feb 18, 2013. 8:03 PM
You were pregnant... In 7th grade? That terrible! I don't know whether to feel bad for you or not.
SamSamBunnyCat in reply to january632572Oct 15, 2012. 5:55 PM
No, a relationship is having a stronger physical and emotional connection. Dating is just like a "Hey, you seem cool, wanna go to the movies?" type thing. Dating can turn into a relationship, though.
jakobnoland in reply to SamSamBunnyCatJan 4, 2012. 1:47 AM
well sir thats your fault i have a girl friend and her dad pulled a gun on me
SamSamBunnyCat in reply to jakobnolandJan 8, 2012. 12:16 PM
Why?! What the hey hey?!
cailynmarie97 in reply to SamSamBunnyCatDec 31, 2011. 8:39 PM
amen, hallelujah sister! ;) i am in 8th grade and i have had my first kiss and i have dated people before but all the guys in my grade are jerks... that is 29 guys (small school)! THEY ALL SUCK! :D so all you little kids out there... keep your hopes up! 999,999 times out of a million your not going to marry any of the kids you have crushes on in grade school! :) thank god for that statistic!
kylewillard12345 in reply to cailynmarie97Oct 9, 2012. 7:09 PM
wow thats it i have 342 kids in my grade
Thundermoon99 in reply to kylewillard12345Oct 17, 2012. 6:30 PM
i got close to 500 theres about 2k kids at my school
SamSamBunnyCat in reply to cailynmarie97Jan 2, 2012. 6:01 PM
And, yeah. It ain't like you're gonna marry any of them. It isn't even really a relationship at our age; actually, it's just like dating. Like, really. You can't be in a serious relationship and truly love someone in middle school.
cuttieluvu in reply to SamSamBunnyCatJan 15, 2012. 12:18 PM
thats a lie u can to if u r like 13 or more as long as u r not really really young so yes! you can not trying to be rude
SamSamBunnyCat in reply to cuttieluvuJan 17, 2012. 4:05 PM
Well, I mean, you can be in a serious relationship but not like a "Oh, I love you. Let's get married and have kids and be together until we die." kinda think. And I know you weren't trying to be rude. Everyone has their own preferences and opinions.(=
cailynmarie97 in reply to cuttieluvuJan 15, 2012. 5:03 PM
no honestly you wont love them. trust me. apperently you havent ever felt love.
Dblax in reply to SamSamBunnyCatJan 5, 2012. 6:21 PM
I wouldn't be so sure about not being able to be in love in middle school, friend. I feel like I'm in total love with my girl. I told her a we're going out. So I feel deeply in love. Gonna try and kiss her soon. :D
SamSamBunnyCat in reply to DblaxJan 8, 2012. 12:15 PM
How old are you?
Dblax in reply to SamSamBunnyCatJan 9, 2012. 8:10 PM
15. And I wasn't talking about total marriage but more of just a long lasting thing.
SamSamBunnyCat in reply to DblaxJan 11, 2012. 7:00 PM
Oh, yeah. In that case, go for it! Like a long lasting thing (like a year or two at least) instead of like a month I guess you could call love.
SamSamBunnyCat in reply to DblaxJan 8, 2012. 12:12 PM
No offense, but I highly doubt you two will marry. Good luck, but don't count on it, hun. (=
SamSamBunnyCat in reply to cailynmarie97Jan 2, 2012. 5:58 PM
You call 29 guys a small school?! I have 9 guys in the whole 8th grade!
cailynmarie97 in reply to SamSamBunnyCatJan 3, 2012. 3:30 AM
Well i went frkm a school of over a thousand students (450 per grade) to 32 kids in each grade. It is really small for me!!!
kylewillard12345 in reply to cailynmarie97Oct 9, 2012. 7:52 PM
where do u guys go to school omg thats so little thats how mny people i have in my class
SamSamBunnyCat in reply to cailynmarie97Jan 8, 2012. 12:13 PM
I have 18 kids in my grade!
cailynmarie97 in reply to SamSamBunnyCatJan 10, 2012. 1:41 PM
oooh that sucks!
awesomecreations in reply to cailynmarie97Dec 21, 2012. 7:53 AM
This is the longest list of replies ever.
tink99 says: Sep 10, 2010. 12:58 PM
omg! i want to be kissed so bad!
Daviktion in reply to tink99Nov 4, 2011. 5:42 AM
Join the club! i haven't even been on a date yet. :'( 13 yrs.
january632572 in reply to DaviktionOct 15, 2012. 4:09 PM
Oh my god get over it you're 13
madame2068 in reply to DaviktionJan 26, 2012. 10:08 PM
Don't worry about it one day you will.
jasonator001 in reply to DaviktionNov 30, 2011. 7:35 AM
i went on a dateand kissed her but she didnt want anyone to know is that bad
1-40 of 1674Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
